Interesting Idea for a Switch for Bed Lights - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Log In
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Old 12-23-2015, 05:35 PM
KCBS Smoker KCBS Smoker is online now
KCBS Smoker is gaining momentum as a positive member of FTE.
I will be installing LED bed lights and have read almost every post on the net about ideas for wiring the switch. I am leaning towards a power wire from the battery to a switch at the rear of the bed, The main concern folks have is forgetting to turn it off and killing the battery.
So I started looking for a switch with a timer and came across this device. http://www.wolstentech.com/products/timedelayrelay/tdr-mc.php It is a integrated relay and count down timer. Just toggle a momentary switch and the device will turn on the LEDs and start counting down. The timing is variable. If you toggle the switch again the timer will cancel and turn off the lights. I ordered one to see how it may work.
I also found a switch and timer module used for rear window defrosters. I thought about sourcing a junk yard switch but found out that the timing circuit in most cars is located in the computer or instrument cluster. Anyway, this device is all contained, counts down for 10 minutes, probably is cancelling, and even comes with a switch. This may be a better solution. https://www.frostfighter.com/thermas...r-controls.htm
Thoughts?
__________________
Lee
2016 F250 2WD CC SB XLT 6.2 3.73 locker, Pscope mirrors, AirLift 5000 bags, LED interior, cab step and bed lights, LoPro QT tonneau cover, BedTred liner, BedTrek bed step,
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH
Old 12-23-2015, 05:47 PM
bayou barataria bayou barataria is offline
bayou barataria is gaining momentum as a positive member of FTE.
That is a great find, I could use a couple of those on my work truck, the helpers are always leaving lights and battery charger on. Not a bad price also. Let us know how they work.
__________________
Sold the 2008 f-250--- Have new 2015 f-350 drw cclb 6.7 diesel lariat 4x4, repainted work top and installed, also added the on board air system, has probably all the options available black interior on blue two tone exterior.
Old 12-23-2015, 05:50 PM
Forgot to mention: the first device is rated 5 amp and the defroster switch is 20 amp.
Old 12-23-2015, 06:38 PM
kengarchow kengarchow is offline
kengarchow is starting off with a positive reputation.
how about putting them on a trip switch like on the doors, so tail gate down lights on
tail gate up lights off
could also add a pilot light inside cab to tell u if u left tail gate open by accident
Old 12-23-2015, 06:57 PM
Sometimes I drive around with the tailgate down.
__________________
Lee
Old 12-23-2015, 11:43 PM
MisterCMK's Avatar
MisterCMK MisterCMK is online now
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
I leave my bed lights on overnight all the time and never have an issue with killing the battery. They do not draw much power. I just put a switch in the rear left corner and that is the only way to turn them in and off
__________________
Chris - Avid Winter Hater
2007 F-250 XLT 4x4 CC SB 6.0 PSD - ARP, IPR Gen2 EGR Delete, 4" turbo-back, no muffler, no cat, 6.4 banjo bolts, SCT X3, EA 270A Alt, coolant filter, air bags, Ranchos, etc.
1994 Mustang GT - HCI, Novi2k blower, MM suspension parts, etc
Hope & A Prayer Motorsports
Old 12-24-2015, 08:10 AM
Quote:
That was my plan, I even have the switch. But Mr. Murphy hates me and would love to kill my battery. I'm the guy that stuff happens to.
__________________
Lee
Old 12-24-2015, 08:55 AM
RightWingNutJob's Avatar
RightWingNutJob RightWingNutJob is offline
RightWingNutJob is gaining momentum as a positive member of FTE.
Alternate Bed lights wiring
I have LED bed lights on my Crew Cab. I wired them into the cab step light connectors that were capped off under the truck. The connectors are on the outsides of the frame rails about 8 inches from the back of the cab.
Click the image to open in full size.
These connectors are energized and work with the cab lights. So if I open the doors or turn on the cab lights manually in the cab - my Bed Lights turn on. What's also great is that they also turn on when I unlock the truck using the key fob. Granted they only stay on for 30 seconds when activated this way, but it's come in handy when I just need to find something relatively quickly at night. If I need light longer I just need to hit the unlock on the key fob again...
My truck is an XLT with "Premium Package" - I don't know if the connectors are installed on XL versions.
They automatically turn off with the rest of the lights - and it looks kind of cool because the dim to off.
__________________
'15, F250 XLT, CC, 172", 6.2L, Ruby Red, FX4, 3.73 Locker, ESOF, Sway bar, Chrome, BackUp Cam, Tailgate Step, Upfitters, Camper pkg, Cab Lts, Husky Liners, Line-X. BAK-Flip HD tonneau cover.
Old 12-24-2015, 09:01 AM
Yep. I have the connectors on my 2016 XLT and am using them for the cab step LEDs. Ford speaker wire plugs fit right into those connectors. I wanted a solution that eliminated the need to use the FOB or leave a door open.
__________________
Lee
Old 12-26-2015, 12:52 AM
Codyaye's Avatar
Codyaye Codyaye is online now
Codyaye is starting off with a positive reputation.
Quote:
I'm also doing bed lights at the moment and what I want to do is get a switch for the negative so when the tailgates up the negative is disconnected and when it's down its on but inside the cab I'll have a button for the positive wire that will always be on but whenever you have to leave the tailgate open around town flip the switch off in the cab. Or for an easier way I was thinking wire it directly into the cargo lights and you can just hit the unlock button to turn it on for about a minute and if you need longer crack a door. If you come up with any other ideas be sure to tell me
Old 12-26-2015, 11:06 AM
Ford'05HG's Avatar
Ford'05HG Ford'05HG is offline
Ford'05HG is gaining momentum as a positive member of FTE.Ford'05HG is gaining momentum as a positive member of FTE.
Quote:
I like both of those ideas.
Old 12-26-2015, 06:29 PM
You can pick up a basic pin switch at your local alarm shop for a couple of bucks, or they are readily available on line.
__________________
Old 12-26-2015, 06:42 PM
I considered these as well. Plunger switch plus an in-cab switch is over thinking the project in IMHO. A simple switch with time out near the tailgate solves the open tailgate issue. I don't want the aggravation of making the cab switch is "on" when I open the tailgate. I also don't want to crack a door to keep the light on. Good ideas though.
__________________
Lee
Old 12-26-2015, 07:37 PM
dwysywd dwysywd is offline
dwysywd is starting off with a positive reputation.
wow...cool thread. i am planning on doing this over the winter, one of my many projects. I'm saving this one!
Old 12-26-2015, 10:34 PM
Codyaye's Avatar
Yeah I can understand that. The cargo lights one is just an idea if you don't want to hook up and go get a switch and figure all that out, just to make things easy. I'm going with the tailgate switch because I rarely leave my tailgate open as is and if I do I have the switch in the cab. It's a bit of a hassle to do for sure but I think in the end it will be worth it. And thanks. Let me know if you got any other ideas, love to hear em!
Similar Threads
will this work? low voltage disconnect device work.truck Electrical Systems/Wiring 25 12-26-2015 11:21 AM
Cool LED Truck bed lights carid Vendor Specials, Discounts, Product Announcements & Group Buys 2 12-22-2015 07:37 AM
My Aux Fuel Tank Install rvpuller 6.2L V8 12 12-15-2014 08:37 PM
2.5kW inverter, RF equipment, Rack install (Note: Many images to load) TRENT310 Super Duty & Heavy Duty 13 10-26-2014 03:46 AM
LED Bed Strip Lighting LaxPlaya21 Super Duty & Heavy Duty 57 07-29-2014 09:58 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
