Trans oil and filter change
Help guys. I need some reassurance that I havent't screwed something up. I recently dropped the pan and changed my trans oil and filter on a 2011 Lincoln Navigator. While doing this, I installed a transmission cooler. I used factory Ford parts on everything. My issue is I drained atleast 6 quarts of fluid from the transmission as I rougly estimated the amount by pouring it into a milk jug. Between spillage from dropping the pan, I think there was a little more than 6 in it. I refilled it and put back in around 7. Could be slightly more but once again there was some spillage. So my question is how much fluid are you guys putting in your transmission. I would take it to the dealer but I don't trust then as the service writer guy says you have to leave car so it can cool down. Wrong. Then the mechanic says he just drives it around, hard for him to get the transmission temp over 195 degrees. Wrong as the Ford service manual says he is supposed to use a scan tool to determine temp. Based on both of these guys I don't trust them, and I really don't trust myself either. They wanted 1/2 hour labor to do this and I don't mind paying but they aren't following Ford protocol. As a side note, the fluid looked new. I recently bought the truck and it has 89,000 miles. Very little metal dust on the pan magnet. Not sure if prior owner had the transmisssion serviced or not. I wanted to change fluid as I plan on doing some towing. I did drive the truck around for 15 minutes and checked it in park ideling. What a pain that is. Make sure you wear an oven glove. Thanks for the guidance.
Your owner's manual says the total in the transmission is 13.1 quarts. Since you only drained the pan about 6-7 quarts is all you'll get out. The only way to get all 13 quarts out is by using a heated flush machine. Dealers are supposed to have them, but most do not.
Why anyone would do a fluid change on a modern transmission by hand baffles me. By the time you buy the fluid , change literally just half of it and do the work, the dealer could have you rolling again with a complete change for a just a few dollars more and a 2 year unlimited mileage warranty on their work.
Didnt know that the dealer offers a 2 year warranty on their work. What a great way to get a free warranty. Is that something they do in your area because I have never heard of the 2 year warranty and they didnt offer the warranty info to me. They did quote me a cost of $180 to drop pan and replace filter. My cost was about $65 for fluid and filter. I also installed a factory transmission cooler at the same time. The dealer quoted me $150 labor for that 30 minute job. I also enjoy working on my own vehicles and enjoy the sense of accomplishment when the job is done. Plus I didnt really trust the dealer as their transmission guy doesnt follow Fords recommendation for checking the fluid level as far as using a scan tool to ensure the fluid is over 195 degrees. I may have a bad local dealer.
Thanks Mark! Your knowledge is always appreciated!
I get the satisfaction of a DIY job but I can't agree on this very general comment of not knowing which fluid to use. A transmission won't operate correctly on the wrong fluid and certainly won't outlast the 2 year unlimited mileage warranty before the dealer has to shell out big bucks to make it right.
Not much harder than an oil change. Do you pay for that too?
Never heard of a warranty on a fluid change. Must be something they sell to the unexpecting.
I am one of those do it yourselfers. I have a good dealer fairly close to me but there is always some inconvenience in taking it in. I keep all my Fluids changed on my Fords myself. I really enjoy doing the work myself. And I educate myself to do the job right. Generally speaking, I can trust my dealer for service, but like everything these days you have to keep your eye on them. I had a 2000 Expedition which had a drain plug built into the pan from Ford. I decided to take it in one time for a transmission flush as I did not have the time right then. They screwed up the threads on the drain plug and it leaked trans fluid immediately when I got home. In the end I had to fix it myself.
I know where my limits are and for those items I always take it to my dealer. Otherwise, I try to stay hands on as much as possible. What I really don't appreciate is Ford making it so difficult to change the Fluid and filter on these new transmissions. I am putting a after market dip stick on mine to make it easier to check fluid and change.
You must be easily baffled. I have 3 dealers within 20 miles of me and none have a heated machine. In effect, what I do in my garage is as good as what they can do.
Just kidding. To each his own.
To me it seems I have a 50/50 chance of something going wrong when I take it to a dealer, which I rarely do any more. It's not a cost saving thing at all but the hassle involved more than anything. The dealers will put the least experienced tech on fluid changes every time.
Just tonight I bought two 5 quart jugs and 3 individual quarts of MC 5w20 plus two FL820S's for 60 bucks even. Pretty cheap oil changes for the truck and wife's mounty. And I can do them at my leisure.
I guess with nearly 23k posts maybe you can invent a way to change fluids from a computer chair.
Admittedly one thing that I've never had an interest in doing is messing with the transmission in any manner other than checking fluid level. Now on the new one's, you can't even do that with out getting under the truck.
I get the satisfaction of a DIY job but I can't agree on this very general comment of not knowing which fluid to use. A transmission won't operate correctly on the wrong fluid and certainly won't outlast the 2 year unlimited mileage warranty[B][B]before the dealer has to shell out big bucks to make it right.
Am I understanding you correctly in that the dealer offers a 2 year unlimited warranty for the transmission if they change the fluid? If so I am an idiot for changing the fluid myself. I would gladly pay $180 every other year for an unlimited warranty on my transmission. My 2011 is out of factory warranty and has 90k miles. Please advise about this warranty. I dont think they have it in my area. If so in what city are your dealers located? Also is this part of some lifetime powertrain warranty that you got when you bought your car and only applies if all work is done at the dealer?
Truckie256
03-09-2014 07:41 AM
