79 bronco steering issues
bought the truck thinking it needed steering gear box. replaced with red head and rebuilt PS pump but its still all over the road. the truck has 4" blocks and body lift with 39.5 " super swampers. the tires are old and cracking even with decent tread left.
i went to junkyard and bought 4 stock tires and rims. when i put 2 on front it drove ok but still felt a little loose. it was a vast improvement over big tires that made it undrivable. I'm going to put other 2 small tires on back tommoro and see what happens. my buddy that did the steer box says front end is fine and no reason to drive bad. could old, big tires really cause it to drive crazy (not play in steering but fight it to keep it in the road at 30 mph)
want to confirm my problem is tires before i break the bank on a set of 37" tires.
thanks
thanks
especially the old belted tires, more than likely when they get up to road temp (which takes a really long time) it would drive a bit better. But odds are if the truck has sat for a long time with them on they have bad belts.
I would also make sure that you don't have a stiff ball joint or stuck front axle u joint. That could also lead to it.
When you say blocks are you referring to the rear? I hope they didn't put that big of spacer in the front, that can also lead to it.
Check your alignment. It should be towed-in just a hair. Any toe-out and it will dart all over the place. The wider the tire and more aggressive the tread, the worse it will drive on the street. Has the trac bar been relocated to keep all your geometry correct, or did someone just throw longer springs in?
I agree it looks like a lot. We talked about a drop pitman arm but my guy said he thought it was ok as it is. Jury is still out on that
What they said ^^ is all true. Having said that those IROC tires will most likely never give you any kind of feeling of a good "safe" ride. It appears the passenger side has quite a bit more wear on the inside. The "scalloping" of the lugs will make it want to dart everywhere. They are great tires for what they are designed for. They are not designed for riding down the highway at 55.
Larger tires = larger stresses. Big tires will always make weak points in steering show up. I run 33x12.50-15s on my '78 and have changed the trac arm bushings, steering stabilizer and had to retighten the mounting bolts at the frame end of the trac arm. It actually started to do the dreaded "death wobble", not fun at 65MPH.
I still believe you would see a big improvement with a drop pitman arm. If I'm wrong here someone explain to me why. The steering geometry is wrong, and it's never going to drive the way it was intended. I've lifted a couple Broncos(80-96) 4" and always with a drop Pitman arm on 15x10's with 33x12.50's. Both drove and handled better than they did before the lift.
