There are a couple of you tube videos on it, I just did mine, took about 2 hours but I was just screwing around,(could have been done faster). I took off the top fan guard and did it from the top, search for the video, easy to do.
I would be replacing the belt tensioner. These engines EAT belt tensioners, which is likely what's causing your belt issue. And in answer to your question regarding how difficult it is to change, the tensioner requires use of only a 15mm wrench for cranking it loose and final tightening, and a short stubby 15mm Gearwrench for spinning the bolt out/in. And it can be done without removing the upper shroud too.
Does anyone know how long or how hard it is to change fanbelt?
Mines separating and slapping on stuff.
well I just fixed vacuum pump oil leak and I have spent approximately 4hrs trying to figure the fan belt out so I don’t know exactly but I bet it take a good while with diagram
Is this on a 6.7 or 6.4? Those two are much different engines with ZERO similarity between the accessory belt drive systems.
