Fuel tank return line
I machined a fitting several weeks ago to solder on top of my fuel tank on my '49 F4 to connect diesel return line. I found out today after several failed attempts to solder it on the tank that I had made it out of the wrong material, it wouldn't take solder. I used a scrap of really tough bronze to machine it from but, it would not tin. I guess there is something in the alloy I used that kept contaminating the surface as I heated it.
This is the fitting I machined
This is the base after several attempts to solder. I ended up soldering a 5/16" ferrule coupling into the top of the tank in its place. It soldered fine.
Here is the fitting and the return line installed. I bored the ferrule fitting so the line would slip thru it as I wanted the return line to go almost to the bottom of the tank. I machined the fitting bolted to the side of the tank to hold the line and hose. I will use a bulkhead fitting for the hose to go thru the cab floor. I machined a bulkhead fitting to fit a 3/4" hole in the frame next to the rear running board bracket.
With this fitting I can connect the hose coming thru the floor of the cab with the 5/16" fuel return line from the engine. I will machine a similar fitting to the one bolted to the side of the tank to connect the hose from the under cab fuel filter to the 5/16" supply line to the engine. I want to get the fuel tank and lines installed so I can get the engine running.
dyoungen
05-03-2011 08:14 AM
wvoburner
04-16-2007 11:50 AM
