Overdrive or not ?
Overdrive or not ?
Been looking at a 1990 f-150 s.c 4x4 with 5.0 engine. Shows to have a 5 speed transmission , is that and over drive and what is the transmission called ? Is it a good reliable transmission ? I have little knowledge about standard transmissions always had automatic . Any information will be very helpful, thanks . JIM
I think that would be the M5OD, made by Mazda. Yes, it's an overdrive 5th gear, with 1:1 in 4th. It's not a bad transmission, but it's not exactly overkill in a half ton either. Should be find behind a stock 302, might not hold up if you go crazy with engine mods (or an engine swap).
edit: My4Fordtrucks scooped me on this...
Well thanks for the information,i'v been looking at a couple of f-150s that have that trany. I'm not a young hot rodder any more , just an old guy that runs into the coffee shop ever so often so i believe it would hold up under my use. I'v been on the dent side and older trucks for several years. But now that i am done building trucks up i will probably switch over to here for information in these years. JIM
Great , somebody told me I needed to use automatic transmission fluid in it . Is that true and if so what kind ? Will it fill from the top though a tube like an automatic one does ? Sorry for all they newbie questions , i have only been working on cars and trucks since 1959 , but all this later stuff is really new to me . JIM
inline 6
21
02-17-2007 11:45 AM
Jcottone
11-24-2005 07:38 AM
iskerbibel
01-07-2005 11:37 AM
Christopher2
11-02-2004 08:10 PM
