390 no-start problem
Trying to help my buddy with his 390.
He drives it once every few months- always runs great.
The last couple of times, he had to really fight to get it started (lacquer thinner, starting fluid, etc). After it started, it ran fine.
The next time he tried- absolutely nothing. The engine will not even sputter.
We've verified a nice fat blue spark (courtesy of a MSD box). The rotor is spinning, so the timing chain isn't broken.
He wants to tear it down, but I think we're missing something simple.
With it not even coughing/sputtering, it seems like an electrical issue, but we've checked that. Could a jumped timing chain do this?
Checked the ignition switch? How about the ballast resistor wire - you'll have a nice spark in 'start' (12VDC) but if it's burned out/gone, in 'run' you won't get the 6 -8 VDC to keep it running.
Brain box (ECM) and connections? ( don't know much about the MSD stuff.....same thing?)
Too much play in the timing chain? - check rotor movement with crank movement. Ignition module? The timing OK?
Many years ago I had a guy at work who drove a 80's full size Bronco and that happened to him. Ended up having to do a ring job. I was blown away at that as I had never heard of it happening before....
I would think you'd get a fart out of at least one cylinder.....What do the plugs look like?
Try the 'ol finger compression test as suggested...you said you have spark.....fuel? Compression test/leak down. Have many mice ( meeses?) gnawing away at the electrical lines? Corrosion on the +/- battery and starter?
With nothing was said about the mileage on the engine, so with it having spark and gas I'd do what hiball3985 said ^^^
vrsc04
07-13-2012 09:07 AM
Rusty_Old_F250
02-21-2012 06:23 PM
shampoop
07-14-2010 10:21 AM
piperig78
02-14-2007 09:33 PM
