Is Wait to Start light totally worthless?
#31
There should be a fusible link and a wire from the left and right shunt posts and center relay post going to the PCM on pins 34, 8 and 9, respectively. The PCM uses those to monitor the glow plugs by watching current draw on each bank. If a bank draws less than 32 amps, or in excess of 8.5 amps less than the other bank, it should set a code and MIL, but only if the glow plugs were commanded on for a period of time greater than 35 seconds.
#32
Didn't notice a difference in the dome light. Voltage, reported through the PCM via OBD, reads 11.56 V when indicator shows glow plugs on, jumps to 12.02 when glow plug reading shows off. So there's definitely some drain when the glow plugs are supposedly on.
At this point, I'm going to assume that my glow plugs are good, and that the 10 seconds that the WTS light is on is not adequate for cold weather. Cycling the key to get fuel pump active again seems reasonable. Next time it's cold, I'll try leaving the key on for at least 30 seconds, maybe longer depending on how cold, then cycling and waiting for the 10-second light.
#33
Funny how old topics keep coming up.
Ten years ago now, my GPR failed on my 2000 miles from home.
Moved the wiring from the glow plug relay to the relay that powers the intake air heater. The intake heater had been removed before, anyway, so it was just sitting there doing nothing. It's been that way ever since. Later on, I disabled computer control of the glow plugs by disconnecting the little signal wire that comes in from the ECU and ran that wire to a momentary on switch that is mounted next to the steering wheel. Hold the button down for a 10 count and turn on the key. Wait another 5 seconds for fuel pressure to build and start it up.
#34
If you have a multimeter, this is a GPR test: Probes across the big studs on the GPR, set to read volts. Just sitting there, you should read battery voltage across the GPR studs. Key on, voltage should drop to zero. Really zero. If you are reading measurable voltage across the GPR studs when you first turn the key on - bad relay or relay contacts.
Also, can please explain why we should see those readings when good, and what is actually happening, when it fails, that would cause the "bad" readings?
I'm a little confused as to why I wouldn't want to see battery voltage on both big studs, when the glow plugs are energized. I thought the whole point of the relay was to "transfer" the voltage to the second glow plug power supply stud, when the relay is activated?
#35
The reason you are not seeing any voltage between the two studs when the relay is energized is due to the fact there is no potential between them, it is like they are two different points o. The same wire referencing each other.if you see the full battery voltage it means that the voltage is not pushing through.
Imagine a pipe with a valve (just like a wire with voltage) if the valve is open then the pressure on both sides of the valve is the same. If you try to read the difference between them (like you are trying to do with your voltmeter) then your reading will be zero. If you close the valve and have 12lbs of pressure on the one side, and then again read the difference between them, then you will see 12lbs/volts.
Now if you went from one stud to ground you should see 12v and if the relay is closed you would see the same 12v to ground on the other stud, and would read 0 if the relay is open.
Hope this helps?
Hope this helps?
#36
#37
Received 3,101 Likes
on
#39
#40
Hope this helps?
Hope this helps?
I don't have the experience the rest of these guys do on these systems, but I wouldn't think that would be enough of a drop to affect the glow plugs. I could be wrong though. I'm surprised I haven't seen any one mention any of the other dozen possibilities that go along with a hard start. With 8 good glow plugs and a strong starter I don't recall having to cycle the ignition twice. The coldest I've seen in my truck are the teens. Now when I had an Autozone starter, which didn't turn as fast as the Motocraft, I had to cycle my ignition a couple times.
Also, did you ever confirm which GP's the shop installed? Around here Autolites are about $2 cheaper per plug. Autolites are also the plugs every one will tell you to steer clear of.
#42
Finally got some weather cold enough (<30 F) to really need glow plugs and see how the truck behaves. Turned key on, waited about 45 seconds. Truck cranked 10-15 seconds, sputtered, died. Did that a couple times until it finally started, ran rough, then smoothed out.
Meter across glow plug relay showed battery voltage (about 12.5) with key off. With key on, voltage dropped to about 11.5. That's not good, right? Should be zero across those terminals with relay active?
Meter attached to hot side of glow plug relay and ground showed battery voltage. Attached to glow plug side and ground showed ~0, with key on or off.
ELM-327 plug and Forscan showed a glow plug cycle time of 85 seconds. With meter showing glow plugs getting no juice, watched Forscan, and heard the relay click when Forscan indicated PCM had turned it off.
So GPR is apparently "functioning" enough to make an audible click, but there's no juice flowing through it when it's "on". I replaced that relay myself this fall, and shop that replaced glow plugs last month said it was good. Maybe they're idiots, or maybe it really was good then. I guess it's time to order one of those Stancor relays, since this one is obviously worthless.
#43
#44
Do you have a part#? I was thinking about ordering the Stancor from Diesel O-Rings, but if there is another good one I can get locally, that would be preferred.
