tranny problems
tranny problems
Hey guys I got a 95 f150, it's an E4OD, and the problem is that it isn't downshifting sometimes. It also somewhat had little lurches when driving (probably because of the transmission not shifting right) there was a wire that I replaced, it was on the engine and a transmission shop told me to try it cuz I was having the same problem before this, and it worked. But now it's back. I also put in a throttle body spacer, not sure if that changed anything cuz the cables to the throttle moved a little but we're adjusted right.
A 1995 F150 can have an E4OD or 4R70W transmission. Either of them are 100% electronic controlled. There is no kick down cable or other mechanical connection to the throttle.
Check for codes.
More details about the wire you replaced.
You wasted your money on a throttlebody spacer. Complete garbage on these trucks.
Check for codes.
monkey jason
02-09-2014 01:55 PM
beagledog
02-27-2008 09:35 PM
ninoford
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
02-21-2008 09:48 AM
93BigBlackBronco
1978 - 1996 Big Bronco
18
03-28-2005 10:56 AM
