Door panel and kick panel templates
I recall a few years ago someone had door and kick panel templates that they traced onto paper. I was seeing if anybody has them still or could make ones for me based upon their backing board. I am willing to pay for time and shipping the paper templates to me. I just don't see spending over 300 bucks buying abs ones from mid fifty when I could make my own. Plus one more thing I could say I did myself.
It's for a 55 f100, thanks.
Midfifty F100 sells imperfect door panels for $20/pair. That would be a good deal as all the holes would be perfectly located. The ebay paper templates are expensive for what you get. They are basically just masking paper and don't appear to have the mounting holes located. I would trace mine for you but they are covered and locating the mounting holes accurately would be difficult.
If you want to try to make your own again I would start with the basic rectangle shape. You should be able to measure and cut that out perfectly on a flat work surface. Then tape that to your truck to finish the curve and mark the holes. The kicks should be fairly easy.
If cardboard gave you problems, I say try it again. You don't want to be practicing with expensive ABS.
