which trannys came with '95-'97 5.8L?
I'll be looking to build up a '52 F3 come springtime, and it has been suggested I look for a roller 351W motor out of a '95-'97 F350.
Three questions for this group:
1) was that motor offered on either the 150 or 250, too?
2) which transmissions (both auto and manual) were available behind the 5.8?
3) was the dually only available in the F350?
Thank you.
Thank you.
Thank you.
Thank you.
2. 4R70w, E4OD were the two over drive autos(but not sure if the 4R70w was available behind the 351) and the ZF5 was the manual trans with OD
3. yes duals were only optional on F350s
the 351s came behind E4OD and the ZF5 in the f250 and F350
Given that he's looking for a 351W for a build (and wondering what trans might be behind it), I'm thinking a small block bellhousing is a plus for him.
thanks.
fwiw, i'll be likely looking for a donor truck to take both the motor and tranny (and harnesses, ECM, etc.)
did just find this helpful resource:
https://en.wikipedia.org/wiki/List_o..._transmissions
...from this, it looks like i'm just as likely to find a C6 in this era?
sure but how many were built, what application were they used in?
Panel vans only? fleet orders only? might be hard to find one for the OP's donor driveline vehicle use.
I only have experience with Eseries and Fseries, never saw any in 92up vans or 92-97 trucks. worked at the Ford dealers from 1989-2000.
thanks for the reply.
so, i wonder if i'm looking for a unicorn... *ideally* i could find a '95-'97 F350 dually with a 5.8 and ZF 5 speed. does such a beast exist? so far all the duallys i've found are 460s and automatics.
95-97 5.8 ?
Bronco ,F150 E4OD only
F250,F350
E4OD or ZF 5spd.
only 5.8 dually would have been an F350
personally I never seen a C6 past a 91 model year, might have still been an option but maybe only on a large fleet order.
good luck with your powertrain donor truck search
F250,F350
E4OD or ZF 5spd.
