Diesel fuel hose leaking
Hi
I have 1997 7.3 turbo f350
In the picture I have a piece of white paper over one of the diesel fuel hoses and that hose has a leak and needs to be replaced.
the other end goes in the block down behind the AC mounting bracket.
My question is. Is there anyway to replace the hose without taking the AC bracket off?
Kyle
Kyle
Just loosen the bracket and slide it forward on the bolts. You can get to the fitting then. If you pull the bracket completely off you will likely brake the ps return nipple off if not careful. Just slide it.. Works like a charm
sorry it took so long to get back to you it has snowed here every day and I have to work outside so it will be a few days before I get to work on it again
Kyle
ok if I understand you I should leave the AC on the bracket?
Kyle
rickm15752
07-11-2017 10:30 AM
dn29626
31
06-30-2010 07:26 PM
