Power steering pulley continues to pop off
Old 12-16-2015, 07:57 PM
giwdul's Avatar
giwdul
giwdul is offline
96 ford f250
My power steering pump pulley continues to pop off, i know its on all the way. the second time it popped off i was able to pull over and grab it, it was hot as as hell. i dont think the pulley was spinning.
i bought the truck sight unseen, installed a new vacuum pump, power steering pump and s belt. when i got it the previous power steering pump was messed up. The pulley itself was off angle, because the shaft was either bent or... something. i like to do my own work and really dont want to have to take this to a mechanic shop.
any ideas?
Old 12-16-2015, 08:08 PM
z31freakify's Avatar
z31freakify
z31freakify is offline
Received 1,180 Likes on 811 Posts
Buy a new pulley, maybe po messed the pulley by enlarging the hole
Old 12-16-2015, 08:16 PM
giwdul's Avatar
giwdul
giwdul is offline
what does po stand for?
Old 12-16-2015, 08:20 PM
z31freakify
[QUOTE=giwdul;15871216]what does po stand for?[/QtUOTE]
Previous Owner
stainlessstroker95's Avatar
stainlessstroker95
stainlessstroker95 is offline
Previous owner. Can you put it on with out a installer?
Old 12-16-2015, 08:32 PM
giwdul's Avatar
giwdul
giwdul is offline
whoa... just went out and messed with it and part of the shaft was ground out and the pulley slipped right on... i dont get how it would do that, its a brand new power steering pump, and last night when i did it the power steering, and everything worked fine. this morning no power steering and this evening all these shenanigans occured
Old 12-16-2015, 11:28 PM
fordpride's Avatar
fordpride
fordpride is offline
The pulley was probably spinning on the shaft and ate it up.
The pulleys are supposed to be changed when removed. They were never meant to be reused although people do my self included. Some never have a issue and some do.
oxt127
12-29-2015 09:22 PM
Fishallday5
10-10-2014 09:10 AM
Dadsole'FORD
04-23-2012 11:18 AM
'78F250351m
16
07-11-2011 02:51 PM
Quick Reply: Power steering pulley continues to pop off
