Grumps 72 F100 Build
The only physical difference between an '03-up P71 (police/taxi) CV front suspension and an '03-up civilian CV front suspension is the coil spring rating. P71 is supposedly around 700# and civilian around 400#.
Also, it's far more likely a P71 front suspension will have lived a much harder life than a suspension from under a civilian model. So, I guess what I'm getting at is you don't have to limit yourself to a CV front suspension from a P71 model.
'03 civilian CV front suspension and a '90 Thunderbird Super Coupe IRS.
Update!
Had to wait til after the new year to get back to my project! Got the 460 pulled out and sitting on the stand. Not sure what mods I'll do on the engine yet. Previous owner said it has approximately 40000 miles on it, seemed to be running fine when I pulled it out. Probably just a good cam and timing set, new intake and carb, a rear sump oil pan, I'm sure the list will grow.
