New guy with codes
New guy with codes
Needing help with engine. I put my homemade Gen3 HPOP on and now when I give it some throttle, computer goes to default of 725 psi and cel. Put new IPR, ICP sensor, and new pigtails on each. I found a thread that helped.
https://www.ford-trucks.com/forums/8...ode-p1280.html
I got connection to the PCM. But is the signal return wire suppose to be grounded?
My mods
96 F-350 RC 4x4 Hypermax Connecting Rods, PIS 300/200s Dyno Proven tunes, Garrett GT4294, Beans IDM, ARP head & main studs with girdle, half filled block, DI cam, ceramic coated bowls, anti-friction skirts, Gen3 over Honey Badger Jr, Billet intake Plenums, Dual SD pumps, Fluidampner, beehive springs, chrome moly pushrods, cosmetic head gaskets, Inconel valves, hardend guides, Ported and polished heads by me, home made RR fuel, 5 speed tranny, with SB 3600 DxD. Snow water meth.
on
1 Post
Glenn, I know the problem you had with your HBJ pump, but the 1280 code is a code for the electrical circuit of the ICP, not the pressure itself.
OP, have you tried pulling the chip and see what it does?
My mods
