1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
99 4x4 hub question.
Old 12-15-2015, 02:26 PM
bigguyinmo's Avatar
bigguyinmo
bigguyinmo is offline
Hey all.
I have a 99 f250 v10 4x4 and I'm having an issue with the lockout hubs. The truck came standard years ago with manual lockouts that have sense been replaced with mile marker lockouts. Problem is I can unlock one and not the other. I have taken the hub completely out and it turns fine but when I put it back on the axle I cannot unlock it. What could this be? Also probably related when I drive it with it locked in and the other locked out and the transfer case in 2wd I get a knocking sound coming from the side with the locked in hub.
Old 12-15-2015, 02:28 PM
Diamnd1's Avatar
Diamnd1
Diamnd1 is offline
Pull both hubs and check for possible missing parts on the hubs and the axles.
Old 12-15-2015, 09:10 PM
r2millers's Avatar
r2millers
r2millers is offline
If it rattling when in 2wd and not in 4wd, it could be your stub hub shaft bearing.
These need to be lubricated regularly and when not, they will start to chatter and make it difficult to operate the manual tabs.
Old 12-15-2015, 09:14 PM
bigguyinmo's Avatar
bigguyinmo
I think you're on the right track because I've never lubed anything down on that side. Is that the shaft right behind the hub?
Old 12-15-2015, 09:46 PM
r2millers's Avatar
r2millers
Yes, the bearing is behind that assembly.
Markus Luukko
07-12-2018 10:06 AM
Mumbly Joe
09-09-2016 02:00 AM
Mich6.0
02-01-2016 10:26 AM
sw2765
Offroad & 4x4
07-06-2010 05:42 AM
mizzitch
03-12-2005 04:09 PM
Quick Reply: 99 4x4 hub question.
