4x4 conversion on a 1988 ford f350, ext cab.
Not the point, the point is they are very often over the GVWR and really pay attention to the laws.
Why?
because they would NOT allow the truck to be registered above the factory GVW, without the truck going at getting certified it was safely capable of doing such, which in turn gets a reconstructed title for newer parts added
More like dodging scales. I do it every day in the tractor trailer grossing 100k
You have to go to a certified Enhanced vehicle Inspection station. I needed to go to one that was certified for heavy trucks because of the weight class(class 7 / 17,000+ lbs)
Then they need to look the truck over to a T to make sure it was put together correctly.
Then you are looking at about $1,500 in fees
Oh and then the title is brandished that it has been reconstructed(like it was totaled and rebuilt) killing the value of the truck. We call then R titles
So you're telling me that you are willing to DAILY assume the risk of the HUUUUUGE fine, significant physical dangers, and significant insurance consequences of being 20,000lbs over in a commercial rig that is CONSTANTLY scrutinized. Yet are unwilling to assume the occasional very minor risk of going a couple thousand at most over the GVWR of a personal pickup that isn't scrutinized much at all.
Brad you're full of it.
I get paid by the ton. the more I carry, the more I get paid. I have a permit to run 100k in NY, NJ and CT(on certain highways). But PA will only allow 80k
And maybe on the west coast pickups are not getting bother by the DOT, but on the east coast they have been getting nailed for the past 15 years
Best way to do it imp is Do what I did and buy a 4x4 srw F350 and comvert it to dually. Get a stock dually rear axle and swap it in, put a dually bed on it, and then get factory Dana 60 adapters for dually off a cab and chassis. These combinations are few and far between and I was fortunate enough to find my sig truck at a good price. This to my knowledge is the only way to build a factory style 4x4 dually and keep the weight rating. I understand hunting down this truck and parts is difficult to say the least and I've spent a lot of time hunting the bone yards to find those front hubs but it is worth it if you can stay dedicated to it
I have a 97 C&C 2wd that I want to swap my 92 f350 4wd suspension and driveline in. How difficult is that? Any issues with the front crossmember? The C&C is 460 gas & auto. The F350 is 460 gas & manual. I may have bent my F350 frame in the middle. The C&C frame is much stronger, no?
As for making a 2wd into 4wd...
You need to mount the spring hangers, track bar mount, 4wd trans, t-case and driveshafts.
BTW the cab-n-chassis have different wheel base length than a pickup, so you need a pickup rear shaft
Actually NO the cab n-chassis frame is no stronger than the pickup frame
#28
It was added top and bottom, at the transition from the cab to the "bed". This was to strengthen the frame where Ford offset the frame rails to match the industry standard 34" width. A straight rail is stronger than a factory bent one with a reinforcement plate
R202INT
12-02-2008 04:13 PM
