signal light
Almost certainly a ground issue.
Clean all the mounting points around the lamp assemblies, spread a thin coat of dielectric grease over em.
Not just the assembly that is giving the grief but all around,.....all 4 corners plus lic. plate light.
Bad grounds do all kindsa funky stuff.
Failing this....take apart each of the "bullett" type connectors where they come out of the steering column clean em up, grease em and put em back together.
But by the sounds of things the ground cleanup should get ya fixed up.
if you need a wiring diagram lemmee know and i can get one to you in the post
Mikie
near ottawa canada
58 m-100 panel & 64 econoline p/u
Mikie
near ottawa canada
tardster
04-12-2010 01:23 PM
robmatt
05-25-2003 04:27 PM
GSchretter
07-12-2000 11:23 PM
