Headlight switch - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Log In
Headlight switch
Old 12-14-2015, 03:16 PM
JimG1098's Avatar
JimG1098 JimG1098 is offline
JimG1098 has a very good reputation on FTE.JimG1098 has a very good reputation on FTE.JimG1098 has a very good reputation on FTE.
Headlight switch
Hi Gang,
Starting my wiring. Need a good headlight switch, 12v
Want head light, park, panel, dome.
Looking at Jegs catalog, Painless 764-80152. $ 65.99
Was wondering if there is anything else comparable for less money.
Original sw has a dead position. and I believe it is the original 6v sw.
__________________
USAF 65'--69'
71st FIS F-106
54 F-750 Fire Truck
http://www.ford-trucks.com/forums/12...ire-truck.html
Empire H&L Co.No.1, Nyack FD, 1965-2001
Old 12-14-2015, 03:46 PM
smallello's Avatar
smallello smallello is offline
smallello has a very good reputation on FTE.smallello has a very good reputation on FTE.smallello has a very good reputation on FTE.smallello has a very good reputation on FTE.
I used this one from EZ wire. I swapped the **** so it looks like the original. I also used the wiper switch and swapped the ****.
EZ Wiring E-Store - EZ Wiring Switches
Old 12-14-2015, 04:50 PM
special 55 special 55 is offline
special 55 is starting off with a positive reputation.
I went with this one:
GM Headlight Switch
For $26 plus shipping I couldn't beat it. It's standard GM wiring diagram and comes with the connector plug and terminals for a nice clean install.
Rich
Old 12-14-2015, 05:07 PM
smallello's Avatar
The one I used is a GM type also.
Old 12-14-2015, 05:18 PM
Phillip123 Phillip123 is offline
Phillip123 is starting off with a positive reputation.
I used a GM type.
Similar Threads
EZ-21 installation question JimG1098 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 12-29-2015 08:03 PM
Cruise Control Cutoff Switch - SW-5957 2003 Expedition sampelje Expedition & Navigator 1 04-26-2015 10:22 AM
2009 F-250 V-10 - Lowest Gears Possible cecilt Super Duty & Heavy Duty 7 01-14-2015 11:56 AM
No headlights merclvr Super Duty & Heavy Duty 0 06-26-2014 07:30 PM
Part Numbers E6UB-9A050-AB and sw48 are they interchangeable? h400exinfl 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 06-26-2013 10:16 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
