6.7L Filter Source?
1st off, thanks for all the great info on here! I have 1,000 miles on my 1st ever diesel and started looking for service intervals. I found this on owner.ford.com, I dont see anything about the fuel filters. Are they supposed to be changed out every 3 months for "Normal Driving"?
Thanks again (Still learning)
Rotate and inspect tires; check wheel end play and turning noise
MEMO: Diesel engine; Up to 13.0 quarts of oil (IOLM)
Change engine oil and replace oil filter when indicated on vehicle message center or every 12 months whichever occurs first (Diesel engines)
Inspect and lubricate 4X4 front axle shaft u-joints
Inspect complete exhaust system and heat shields
Refill diesel exhaust fluid tank
Inspect fuel cooling system level, coolant strength, and hoses
Inspect brake pads/shoes/rotors/drums, brake lines and hoses, and parking brake system
Check engine air filter restriction gauge, replace filter as required
Inspect engine cooling system level, coolant strength (anti-freeze & anti-corrosion) and hoses
Inspect and lubricate all non-sealed steering linkage,ball joints,suspension joints,half and drive-shafts and u-joints
Perform multi-point inspection
Thanks for the info, I have looked for videos on the water separator and cant find any, any ideas if there are any on here?
