2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Question about trans fluid change?
Old 12-13-2015, 02:42 PM
svfetter's Avatar
svfetter
svfetter is offline
For those who have changed the fluid and filter theirselves on these new transmissions with no dipstick, how did you put in the new fluid? Most do it yourselfers do not have a fancy pump assembly like the dealers do.
Old 12-14-2015, 04:13 AM
Gg6k's Avatar
Gg6k
Gg6k is offline
There are good videos on you tube. If you have the Ford built transmission, not the ZF, there is a bolt on the drivers side of the transmission. Once the bolt is out it will reveal a small yellow dipstick. You have to pump in the transmission fluid by hand. The guy on youtube is ford tech makuloco or something like that. Keep in mind I havent done mine yet so I am giving a recap of the video. Good luck.
Old 12-23-2015, 01:01 PM
Gg6k's Avatar
Gg6k
Gg6k is offline
Ok. Just did mine so what I did was use a long piece of tubing and run it from the fill/dip stick but assembly up thru the engine compartment and then put a funnel on the end in the engine compartment. Slowly pour in the fluid. Mine took about 7 quarts but I did install a cooler so I may have needed more fluid than a regular oil/filter change. Hope this technique works for you. Checking the fluid level is a pain. Use an oven MIT to prevent 3rd degree burns.
Old 12-24-2015, 11:14 AM
13expedition's Avatar
13expedition
13expedition is offline
Old 12-28-2015, 06:23 PM
berry1234's Avatar
berry1234
berry1234 is offline
Originally Posted by 13expedition
You can also use a pump for quarts. The pumps are cheap and can be found on amazon or similar places.
Amazon.com: Plews 55001 Lubrimatic Fluid Quart Pump, Fits Standard Quart Bottles: Automotive
Great find!
medic503
07-12-2013 11:52 AM
true blue
01-15-2011 09:09 AM
sammy77
03-01-2010 12:46 PM
boatnfish
1997 - 2003 F150
08-17-2008 08:17 PM
BrianA
03-13-2006 01:02 PM
Quick Reply: Question about trans fluid change?
