Lower radiator hose/Tee going to what?
1994 E150, club wagon, 5.8
Lower radiator hose connects to a tee / branch. Is that tee for the oil cooler?
Like this pic:
Gates 22401 - Molded Coolant Hose | O'Reilly Auto Parts
Thanks.
Like this pic:
Thanks.
I found out that its an oil cooler adapter. I ordered one and its looks kinda
odd. The hose and plastic is 1 1/2" inside diameter but on the inside there is
a ring that is part of the mold that constricts the flow down to what looks
like could be 1" I am going to be sure to compare it to the old one I take off.
Thanks.
Thanks.
I took off the old oil cooler adapter today and it is has a bit larger Inside
diameter.
The new one has what looks like only a one inch passage (Not all the way
through, just between the two small hoses on the inside) This has me
wondering if thats going to be a problem.
It is an original gates brand.
Has anyone had this same experience or know if this is a problem
Thanks.
diameter.
Thanks.
diameter.
After looking at my old one and some online, I am wondering if this is a
counterfeit. I bought it off amazon, (wich I have never done before and will not do again) from
a place advertised as gates. It looks very different than the original but it
installed the same. It came with a gates sticker like all gates products I
have bought in the past.
Thanks.
diameter.
Thanks.
not that it will do any good, but what is the part number?
i ordered some Motorcraft parts online and was concerned about them being counterfit. I called ford and they sent me to a division that handles that.. She had me to take pics and send them to her.. She said they all looked real to her.. The coil wire still slips off the coil. I had to tie wrap it on.. Also no where on the DSII module did it say Motorcraft!
The part is a 22401
This is the site I bought if from, The amazon web store is called Gates
It was not in a box with a label so there are no numbers to check, it was
loose in the shipping box like a bulk item and had a gates sticker on it.
I saw that gates counterfeit check page when I was looking into it. I have
emailed gates and explained the situation.
Could be a genuine or not but either way that constricted section of the
hose is very troubling, especially since it was a extremely difficult job to
install.
Thanks.
install.
Thanks.
The part is a 22401
Amazon.com: Gates 22401 Lower Radiator Hose: Automotive
install.
Thanks.
install.
Thanks.
No idea if this applies, it just sounded familiar.
jim
I am wondering if the constriction is to control the coolant flow through the cooler? I have seen similar reduced diameter hoses used on heater cores to reduce the pressure/flow through the heater core to avoid early heater core failures. GM had this problem on their pickups many years ago, I learned of it from a friend who was having the problem. He told me the last time the dealer replaced the core that they installed some kind of reducer in the heater hose.
jim
jim
Thanks.
jim
oldstylefseries
01-11-2006 01:43 PM
crittersale
01-05-2005 12:11 PM
ppoel
08-07-2000 08:21 AM
