North Carolina Chapter Join Chapter, Leader:Benztechnc
Official NCFTE Works Thread
Old 09-26-2016, 09:36 AM
ncheavymetal's Avatar
ncheavymetal
ncheavymetal is offline
Sorry you couldn't race Larry. Hope you get her patched up for the next one.
  #452
Old 09-26-2016, 10:32 AM
ubereal2's Avatar
ubereal2
ubereal2 is offline
Matt, you could do it the way us poor boy's did it.
Get you a piece of clear tubing. Connect it to the return side coming out of the gear box, and drop it into a bucket, unless your not worried about deposits, or EPA.
You may need another pair of hands around to keep pouring clean power steering fluid into the pump, while the engine is running. You'll see the color difference in just a short while through the clear tube
  #453
Old 09-26-2016, 11:39 AM
quest4reds's Avatar
quest4reds
quest4reds is offline
Originally Posted by Benztechnc
Oh and something like a MightyVac comes in useful for a lot of things.
1. single person brake bleeding, though there are fancier units available for this.
2. testing manifold vacuum. Great for timing an old engine.
2. evacuating old fluid, use the same as the brake bleeding procedure.
3. Vacuum testing systems to find air leaks (such as pulling vacuum on an egr valve to verify it is working.
https://smile.amazon.com/dp/B00265M9..._Ket6xbM6VC8X4
Josh, that is surprisingly similar to the unit they have pictured in the instructions! Learning that it is a useful tool to have around for a number of applications, not just a specialty tool I can use for a single purpose, I'll look into picking one up. I have heard one of the 'must have' items for any respectable garage is a vacuum guage, looks like this would cover that as well.
  #454
Old 09-26-2016, 11:42 AM
quest4reds's Avatar
quest4reds
So what I'm hearing is flush out the old fluid plus loose impediments, and fill with new clean fluid, not necessary to bleed new pump with vacuum?
  #455
Old 09-26-2016, 01:37 PM
ubereal2's Avatar
ubereal2
ubereal2 is offline
Exactly, but without all of the big fancy words. Your flushing out everything. You'll only have new, clean fluid
  #456
Old 09-26-2016, 02:30 PM
Cracker289's Avatar
Cracker289
Cracker289 is offline
My cousin let me borrow his vacuum pump sucker tool thing, and it was very handy. I was doing brakes on the old project truck, and when I saw how handy it was I did transmission fluid on my Nissan car and oil change on my F100. I can definitely see it being great for sucking out the power steering fluid lines, etc. He said it was like 20 bucks.
Models | LiquiVac
  #457
Old 09-26-2016, 03:39 PM
Benztechnc's Avatar
Benztechnc
Benztechnc is offline
Models | LiquiVac
Fluid evacuators are great. Though I haven't used mine in ages.
5 or 6 gallon fluid evacuator. (Vacuum pump suction device thingermajig)
  #458
Old 09-26-2016, 06:53 PM
quest4reds's Avatar
quest4reds
I'm sorry, I let some of my nerd slip out.
  #459
Old 09-26-2016, 06:59 PM
quest4reds's Avatar
quest4reds
So that's how you spell 'thingermajig'! I'm going to add this to my list of 'big fancy words' like impediments just to keep y'all on your toes.
Seriously though, would that hand pump vacuum doohickey Josh talked about earlier do pretty much the same thing minus fluid collection or am I mistaken?
  #460
Old 09-27-2016, 08:23 AM
Benztechnc's Avatar
Benztechnc
Yes, it has a very small resovoir that can be connected in line. It's typically used to bleed brakes. Rather than using the pedal-Master cylinder to push the fluid out. You just fill the resovoir and suck the fluid through the bleeder screw. It would also work if you put it the line in the reservoir. However, I use something like a turkey baster if I'm just cleaning out the reservoir. In fact a baster would probably be real cheap and can get it from anywhere. If you had that, I would say go ahead and do the resovoir on the PS and then the brake fluid. Wipe them both out with a clean cloth and refill ready for bleeding.
  #461
Old 09-27-2016, 10:36 AM
quest4reds's Avatar
quest4reds
Thanks Josh. Sounds like a worthwhile tool/instrument investment.
  #462
Old 09-27-2016, 01:56 PM
77mud's Avatar
77mud
77mud is offline
The Mighty vac are pretty cool, we use them at work when hand bailing fuel from wells. We typically get about 6 months out of them, but we use them alot. We probably get 100 gallons in that 6 months.
  #463
Old 09-27-2016, 04:27 PM
quest4reds's Avatar
quest4reds
Good to hear. Sounds like for me it should last quite a long time.
  #464
Old 09-27-2016, 04:50 PM
77mud's Avatar
77mud
77mud is offline
Definitely, and the fact that some of the guys at work don't respect something that isn't theirs.
  #465
Old 09-28-2016, 07:53 AM
Benztechnc's Avatar
Benztechnc
There is always one in every crowd. Which reminds me... stupid trailer blowing fuses, and Ford using fuses that you can't find any where so I had to special order them from the dealer!
Quick Reply: Official NCFTE Works Thread
