Is my truck worth fixing?
Hey guys, here's what I've found out so far. I have a 1996 f250 xlt auto 2wd with 93,500 original miles. I had my covers pulled, and 5 of my injectors are running terribly. On top of that, my hpop is crapping out and I have a big fuel leak at the banjo bolt and blue lines are cracked. All in all I was quoted around 5 grand to fix everything but I'm not sure it's worth it. What's your opinion? I love the heck out of my truck but that's a pretty chunk of change. Any advice would be appreciated. Thanks.
Boggin Dave
Boggin Dave
Boggin Dave
Boggin Dave
With our guidance you should be able to do it all your self for way way less than that, all you need is ti ask friendo
You can definitely do it for less then half of that if you are mechanicaly inclined enough.
I have a hard time believing the injectors went bad that early. Earliest on the infamous 6.0 I've done is 180 (I blame a bad ficm) so maybe the hpop caused the early failure
Rebuilt rosewoods- cost at 1,250.00
Rebuilt 17* terminator at 500.00
Replacing fuel lines, fuel bowl, and fuel pump- 900.00 parts and labor.
Add those up that makes 2,650.00
Then he's charging for 8 hours just to pull the injectors and hpop and put them in. Shop charge is 130.00 an hour which is the going rate where I live. Then he's replacing the uvch and glow plugs plus new relay. It definitely doesn't add up to 5k but I can't do this myself, I don't have the time, and I don't trust myself honestly. I wish I could find a better shop. I live in San Francisco bay area and the mechanics around here that I've been to suck ***.
on
1 Post
I need to reflect back to your first post in this thread https://www.ford-trucks.com/forums/1...hopefully.html
You said every mechanic you took the truck to was bad. Don't think for one minute that the one that told you your injectors and HPOP are shot on a 93,000 mile truck is any better. I call BS. I honestly do not believe that all that stuff is wrong with your truck, and you are getting taken on a $5000 dollar ride.
I know it's expensive. Here's what the mechanic have as an estimate.
I'm calculating $3,690 from your amounts not 5k. the important thing is how much do you like the truck AND more important how long do you plan on keeping it. 3 years? Put 100 bucks away once a month and you got your money back in three years. 6 years? Put $50 away.
Did you try to negotiate the labor rate or the bill overall.
Hi Mechanic man
Hey Dave
Listen I would like for you to get the repair job on my truck but I can't do it for the initial quote you gave me. It's a little steep. What discounts can you do to make it financially satsfactory for both of us.
Well Dave let me see what I can do
(I usually pull out cash and price drops pretty good)
Doesn't sound like you drive the truck much with that low mileage. What was " bad" about all the mechanics you went to? Did they all diagnose the same thing?
So he's either gonna drop the price or he is not. But either way you're back to square one or got money off. Never be afraid to ask for a discount. The worse they say is no. I've never had anyone say no.
I'm driving a 2001 truck. I just did a complete paint job and fixed my AC compressor for $3800. Plan on keeping the truck for another 10-15 years. My option is to buy a used something for 25-35k or new for 56k.
Seems pretty steep on labor considering once he takes off intake and valve covers everything is right there.
Hi Mechanic man
Hey Dave
So he's either gonna drop the price or he is not. But for youre back to square one or got money off. Never be afraid to ask for a discount. The worse they say us no. I've never had anyone say no.
Hi Mechanic man
Hey Dave
Agreed. And if 5 of the injectors are bad, may be worth replacing them all so you don't have to go back in. At 93,000 I wonder what was wrong. Did you buy this truck or have you had it for all 93,000?
I'm not sure, he didn't check those out. If the o-rings are bad would that make my truck run like absolute crap? I'm not stupid, I just really need a better understanding of what might be causing this.
Ok, so let's just say for the sake of being positive that my injectors are fine, and the hpop is fine. Besides my fuel leak, what would cause my truck to romp at startup, smoke while in reverse, have surging issues (best way I can describe it), be slow until she's warmed up, and shake at idle? All these things concern me. I'm just not ready to give up on my truck but I definitely don't want to sell myself short either. If all those parts are ok, what else "could" be the issue(s)?
Dont be intimidated on working on your truck, we all started from not knowing anything like you for example you learned how to install a brick walls and what not, same concept in a vehicle.
As I mentioned earlier with our guidance you will be one with your truck and know what true love is i mean know your way around the 7.3 and wont have to deal with pesky mechanics. As for your injectors maybe the leaky fuel bowl has something to do with the injectors acting up (air in the fuel system) Just lets us know brother were here to help your in the OBS brethren now
