Fuse panel location Ideas
on
Hi Gang.
Getting ready to mount my fuse panel and would like to hear pros and cons of locations.
My first option is mounting it in the foot well drivers side. Actually, the box would set in the recess in rear of fender where the three bolts are.
My second option is in the engine bay on the fire wall or on the inner fender.
I have an Easy 21. Drivers side. Concerned about heat from manifold, etc.
any and all thoughts would be appreciated.
I used an under dash steel filler panel that I mounted up next to the firewall using 90 degree brackets. I wanted a clean firewall, so putting screws into the firewall was not an option. This panel has the fuse box by my left knee, various relays towards the middle and the ecm behind the glovebox.
I mounted mine to the left of the steering column. I fabbed a bracket to mount the box to my hanging pedal assy so that I wouldn't have to poke holes in my firewall. I mounted my box upside so that the main bundle of wires exited upwards rather than downwards (I used the 21 circuit EZ Wiring harness)
I'm using an old Bell Systems box. It's actually bigger than I wanted, but it fits pretty good.
I have it attached with magnets, so I can pull it off and stick it to the door for fuse work. There are a lot more wires than in this picture.
Then with it on the door it will look something like this. Now, I'm a little worried how the wires will look when I get them all in. It looks like a rats nest at the moment in the midst of my wiring.
I can't take credit for the idea.
https://www.ford-trucks.com/forums/1...l#post15171804
Ok, I'm not the smartest at electrical stuff - in fact it's my least favorite part of my rebuild. But now I'm confused.
I did the 6V to 12V conversion, and rewired everything under the dash to engine using a harness kit, but haven't done anything, or even realized I had to do something, about fuses.
Help please.
Help please.
