Worst Halogen Headlights Ever
I wish I could have purchased the LED headlights, but couldn't because I had the plow prep option. These halogen headlights are awful, it's so dark and I can't see at night. I just ordered the Morimoto LED fog light assemblies and hopefully that will help some. They were $200.
Has anyone upgraded their headlights to LED or HID? I saw a thread a while back, can't find it now - but was wondering if I need to spend the $1,600 to get the whole OEM upgrade LED housings? I saw some kits out there for a few hundred bucks - who has experience with them?
I have to do something because I'm concerned about safety and need proper headlights. Ideas?
Thanks,
Paul
Thanks,
Paul
I don't get it. Every vehicle forum I've ever been a part of has people complaining about how awful the factory headlamps are. The only vehicles I've ever driven with what I thought were substandard headlamps were heavy trucks.
Have you thought about getting your vision checked? Not trying to be a smartass at all, but if the factory head lamps aren't bright enough there may be something wrong. As you upgrade to brighter, non-DOT-approved lights you may be creating a hazard for those around you.
My initial thought is to verify the headlights are adjusted correctly.
Josh
Crazy, I was just going to do a search to see if anyone had changed bulbs and this was the top of the forum. I have the halogens as well, but I don't have a problem seeing with them. My concern is with the LED side mirror lights (which I LOVE), and the LED taillights, I don't like the contrast in lighting colors. The LED are all a bright white, which I prefer, and the headlights and fogs are the warm lights. I would like to get them all to match color as close as possible.
I have not used the amber fog lights GlueGuy speaks of, and since I don't have near the fog that I'm sure he drives in in the mountains, I just like the look of the heads and fogs in on-coming traffic so I run mine 100% of the time. I wish you could bypass the fogs turning off when you hit the brights.
Might try checking the adjustment of your headlights. As a retired service adviser, I've had customers complain about poor headlight performance, and many times the problem was poorly adjusted headlights. If they are adjusted too low the beams will not project for enough forward, which gives the illusion of dim headlights.
