Hard shifting after warmed up
I have a 1993 Ford F150, 6 cylinder with an automatic transmission. The previous owner didn't do a lot of maintenance and I've been slowly getting it up to speed. 195k miles.
After driving the truck for an hour it will start to shift really hard. I was thinking about changing the fluid and filter. Is there anything else with the transmission I should maintenance?
C6 was not available on a F150 in 1993. It was available on F250/350 until ~1996. Seems to be a special order/fleet/govt. option.
on
The one possibility for an non computer controlled transmission in a '93 F150 is the AOD but it is not known for developing hard shifts out of the blue. However the electronically controlled transmissions are known for exactly this because that is what the computer is programmed to do when it experiences communication problems with the trans or sensor problems with the engine.
Check the door jamb sticker on the driver side B-pillar. Look for the TRANS code:
It should be TRANS Code: E (E4OD). It's a 4 speed automatic transmission.
TRANS Code T is an AOD (not available on a F150 w/I6 engine)
TRANS Code U is a 4R70W (not available on a F150 w/I6 engine)
Thanks for the help, it's a Type E (E40D). I took it to an old time transmission shop that's around the corner. Classically it drove perfectly and the shifts were great. He thought it might be the solenoid pack. As it gets hot it acts up.
As the pack is only $130, I thought I'd change the pack, fluid and filter. Hopefully, if that doesn't solve it I move to the neutral switch.
A Code check is free....
Warm up the truck then do this: How to run a self test.
Run the Key On Engine Off (KOEO) tests and stored code (Continuous Memory aka CM) display. List any codes you receive by number and when they were displayed. You should get three digit codes.
fordguy2009
03-27-2009 02:08 PM
tallendavisjr
1999 to 2016 Super Duty
12-03-2005 09:14 PM
