1994 Powerstroke Stalls Until Warm
Old 12-11-2015, 10:38 PM
John_Forbush's Avatar
John_Forbush
John_Forbush is offline
I traded for a 1994 powerstroke, ran great for a few days. Now upon cold starts, especially in the morning, the truck will start fine, run a few seconds and then start missing really bad. Then it stalls and you have to crank and crank like it ran out of fuel, then it'll start and stall and start and stall and eventually stay running but miss and not take fuel and smoke either blue or white. Truck has new injector harnesses. It doesn't do it when you plug it in. Also, it smells like its burning rich on the exhaust. It's a 1996 California engine running on a 1994 pcm too. Could that be the problem? It only has 149,000 miles on it. Any help would be greatly appreciated.
Old 12-12-2015, 07:00 AM
ReBilld's Avatar
ReBilld
ReBilld is offline
Cali trucks have different injectors and different tuning. Also sounds like you may have bad glow plugs and/or glow plug relay. If it starts fine and doesn't do it when you plug it in, that is a tell tale sign of glow plug or relay issues.
Old 12-12-2015, 08:27 AM
John_Forbush
I just put glow plugs and a relay in it...
Old 12-12-2015, 09:40 AM
ReBilld's Avatar
ReBilld
ReBilld is offline
Maybe a tuning issue with the injectors and the '94 PCM.
Old 12-13-2015, 03:21 PM
97-psd's Avatar
97-psd
97-psd is offline
I would recheck the wiring. If it starts well with it plugged up it is he rally a sign that the glow plugs/relay are not working correctly. Try jumping the relay and see if that helps the starting process.
What brand of plugs and relay did you use?
After it warms up, does it have any issues?
Old 12-14-2015, 09:04 AM
John_Forbush
Already tried it. No change....
Old 12-14-2015, 09:08 AM
John_Forbush
New symptoms: when going down the interstate (70 mph) it starts dropping power, smoking blue or white, and decelerating down to around 45 to 50 mph before taking off again. It started that 2 days ago, now it does it at all speeds. Its like the fuel is being cut off from it. Sometimes it drops down to 1,100-1200 rpms on the tach and wont take any more fuel than that.
Old 12-14-2015, 09:31 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
MOOSE_MACHINE is offline
Have you noticed if it does it differently going uphill or down?
Old 12-14-2015, 07:33 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Have you checked the fuel pressure?
Old 12-14-2015, 08:29 PM
John_Forbush
That's next on my list.
John_Forbush
It's the same either way.
Old 12-16-2015, 08:39 AM
John_Forbush
I got it taken care of. Changed fuel filter, put an air filter in it (it didn't have one) and topped off the oil and now it runs great.
CaptainFacePunch
05-14-2016 08:48 PM
Kp-rewired
11-16-2014 02:29 PM
outdoormaniac
11-30-2009 11:56 PM
desert sled
03-05-2009 11:44 PM
GK4x4
02-05-2009 02:06 PM
Quick Reply: 1994 Powerstroke Stalls Until Warm
