97 F250 rear brakes full of oil
Hello,
Recently purchased my first Ford truck, a 97 F250 w/7.3L diesel. I discovered the passenger rear drum brake was full of oil. Cleaned it up and put it back together to do some research.
I see how the hub comes off and there are two bearings in it an an oil seal. The bearings are lubed in wheel bearing grease. Does differential oil circulate through the bearings too?
It doesn't look like a difficult job. Do the seals go bad often or could this be due to a clogged differential vent? Truck has only 100k miles.
Any gotchas I should be aware of?
Thanks in advance!
Thanks in advance!
Received 3,102 Likes
on
Thanks, yes I still have the problem. First thing I checked was the smell and it didn't smell like differential oil, but the wheel cylinder was the only part of the thing that was dry. Go figure. It was a real gooey sticky mess. I didn't have time to mess with it and the leaking fuel pump so I took it into a shop.
I'll post the answer as soon as I get it back.
Thanks!
Thanks!
on
Timbid
15
03-21-2018 11:09 AM
Snuggyworm
05-25-2014 10:04 PM
