oil line to use for remote oil filtration system
Is there an oil line that can be used to install a remote oil filtration system. found a system that can filter down to 1 micron and claims to remove soot, so Im interested in trying it.
I think I recall seeing that the 6.4 has an oil heat exchange that is half oil cooler and half coolant cooler and in this mode...the only lines involved are the ones to the coolant radiator......no oil lines that actually go to a cooler????
I know about the caps that can bypass oil flow from the oil filter cap thru a bypass filter and then to the fill cap....but I want to see if I can install a remote location full flow oil filter instead of the bypass one.
speakerfritz
1999 to 2016 Super Duty
12-12-2015 04:42 AM
the_auto_tech
11-22-2012 10:05 AM
Old Blue Crew
05-07-2004 01:38 AM
