1978 - 1996 Big Bronco
Axle yoke/Lower Ball Joint stud knocking
Old 12-11-2015, 08:12 AM
ARK-F150's Avatar
ARK-F150
ARK-F150 is offline
This morning I started reassembling my Dana 44 after replacing upper/lower ball joints. After installing the knuckle and torquing the upper and lower ball joints to proper specs I found that the axle yoke is knocking the lower ball joint stud. I've read that many just grind down the stud but is this the proper way? Also, the upper doesn't seem to full engage the A frame. What's the deal? (It's not flush like it was when I took it out)
Thanks
Old 12-15-2015, 02:32 PM
g_k50's Avatar
g_k50
g_k50 is offline
Grinding down the stud is not the proper way.
It should go back together without any grinding.
I'm just guessing, and bumping, but I think the yoke is not fully engaged into the housing, it needs to go further into the housing., But again, I'm just guessing.
Re-examine your install procedure for misstakesl.
Old 12-20-2015, 07:15 PM
My4Fordtrucks's Avatar
My4Fordtrucks
My4Fordtrucks is online now
Received 1,360 Likes on 1,074 Posts
Wrong joints or put them in the wrong place? Replaced 3 sets of ball joints (3 different trucks) in the last handful of years and never ran into that problem.
andrewrj
16
04-12-2014 03:36 PM
fomoco32
03-10-2009 08:24 PM
hucka1a
10-26-2008 09:43 PM
My96Bronco
08-08-2006 10:25 PM
Quick Reply: Axle yoke/Lower Ball Joint stud knocking
