Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1979 F800 Dump Truck Carb Question?
Old 12-11-2015, 06:45 AM
skd91's Avatar
skd91
skd91 is offline
Hey I am wanting to replace the 4 Barrel carb on my Dump Truck and I would like some advice.
I have a 385 series, 370V4 with a 5 speed behind it, manual choke.
The carb that it currently on the truck was rebuilt by the previous owner. and shows that it is a Motorcraft by Holly. it has some sort of governor on it that has been disconected, thing just not running right.
Have to leave the choke out for quite a while to warm up. then it just don't seem to have a lot of power. I have never got the secondarys to open up.
I was wondering if anyone has any suggestions for a replacement? and where to purchase.
Thanks Steve!
Old 12-12-2015, 08:43 AM
tree medics's Avatar
tree medics
tree medics is offline
Find the number on your carburetor. Go to www.autoline.ca and do a cross reference. Than you should be able to go to a parts store and order your carburetor with that number. The autoline number on my carburetor is C-7488, but this is for a 1985 F-700 370 - 4V. I have done this before because a lot of guys at the parts stores won't look things up. I hope this helps!
Pat.
Old 12-12-2015, 07:59 PM
skd91's Avatar
skd91
skd91 is offline
Hey I went to the site. but no Cross Ref????
Old 12-13-2015, 12:53 PM
tree medics
Did you click on show me the parts? Then you click on cross reference.
Old 12-13-2015, 06:12 PM
skd91's Avatar
skd91
skd91 is offline
OK I did not see the tabs at the top of the page.
Thanks!
Old 12-13-2015, 10:40 PM
tree medics
Thanks!
Your welcome, if you can't get a number off their site you can phone them I've done that before.
Old 12-14-2015, 02:51 AM
big job's Avatar
big job
big job is offline
Hollys with a governor I believe a G model little tough now a days to find. I just got
my 2016 catalog from my Napa guys. I would go for a 4160 square bowl Holly. If you can't get a manual choke carb just remove electric choke and put your manual on it.
Your symptoms say somethings going on with a blown power valve and or/ metering
passages or got some blockage in venturies. And then a $30 kit should do the trick.
After all said and done, we always fill the carb with fuel and on the bench blow shop
air down its throat to check how it atomizes while holding wide open throttle (cheap
trick) Getting it to run good with the choke out means it is not atomizing correctly.
CougarJohn
01-03-2013 03:25 AM
tygerrrr
07-01-2009 09:54 AM
64fordf100292
15
08-09-2007 10:52 AM
Ford_250
06-29-2007 11:27 AM
charles jones
03-12-2006 12:36 AM
Quick Reply: 1979 F800 Dump Truck Carb Question?
