04 Excursion 6.0 Limited RWD
Year: 2004
Make: Ford
Model: Excursion
Price: $18900
Mileage: 166000
Color: Pueblo Gold Metallic
Private or Dealer Listing: Private Listing
Location (State): CA
Transmission: Automatic
Drivetrain: Rear Wheel Drive
Color: Gold
Engine: 6.0 Powerstroke
6.0 Liter 32 OHV Power Stroke V8 Turbo Diesel Engine
5 Speed Automatic TorqShift Transmission
3.73 Limited Slip Sterling 10.5" Rear Axle
16 Way Heated Power Adjustable Leather Captain Seats
Rear DVD Entertainment System with Controls
Rear Parking Sensors
8 Passenger Capacity
Towing Package Rated for 11,000 lbs
Rear Barn Doors with Glass Hatch
Illumiated Visors
Power Vented Rear Windows
HomeLink Auto Dimming Mirror
Heated Power Telescoping Tow Mirrors
44 Gallon Fuel Tank
2 Batteries
Fog Lights
Illuminated Running Boards
Roof Rack
Day Time Running Lights
Steering Wheel Audio Cruise and Climate Controls
Paint Matched Steel Front Bumper
Block Heater with 120V Connection in Front Bumper
Keyless Entry Keypad System
Aftermarket Accessories Include:
RideRite AirBags and Compressor Suspension System in the Rear with Air Lift Driver Controls
Volant Cold Air Intake System
17" Steel 8 Hole Wheels
Bully Flat Black Locking Fuel Door
Kenwood Bluetooth Radio w/ Pandora and IHeart Radio
Bosch 135 Amp Alternator
ScanGauge II
Grade 12.9 Upper Rear Shock Mount Bolts
Trailer Brake Controller Ready
New MotorCraft Sway Bar Bushings and End Links
New MotorCraft Severe Duty Front Brake Pads
New KYB Gas-A-Just Rear Shock Absorbers
Alignment Recently Performed
EOT-ECT Deltas are only 10-15 degrees at all times. Oil & Filter Changed Every 3k miles with Shell Rotella T 15W-40, Fuel Filters Changed Every Other Oil Change, Only MotorCraft Filters used. Fresh Amsoil Severe Gear 75W-140 in the Rear Differential, Amsoil Fuel Efficient Synthetic ATF in the Transmission, Fresh Peak Final Charge Coolant Flush, and Amsoil Diesel Injector Cleaner in Every Tank. I am the 2nd Owner, Clean AutoCheck with Clean Clear CA Title and Smog Check in Hand. Registration is Good Through 09/2016. Adult Owned, Garage Kept, Not Lifted or Heavily Modified. Asking $18,900 OBO.
I bought a new truck so my Excursion has to go because I don't have enough room in the garage for both of them. I listed it with No Reserve Price on eBay, the high bidder takes her home:
Ford Excursion Limited | eBay
Cody Phillips
08-09-2019 05:56 AM
