Can I disable the "TIRE PRESSURE SENSOR FAULT" message?
So I brought my 2004 Expedition EB to the UK and over the last year or so had a lot of fun n games with the TPMS snapping off and after 4 "replacement" units and wasted money I have given up getting it working again. (The original TPMS are no more and the replacements either don't work or need an expensive tool that nobody in the UK has - either way me and 2 garages can't get it working).
So to pass our MOT test I need the error message to stop. Every time I switch on I get "TIRE PRESSURE SENSOR FAULT" on the message panel.
Can I disable that? It's legal here to do so but I can't find it documented anywhere.
thanks
Mike
thanks
Mike
The only way to disable that is to get the system working. It's not too difficult, I just did it on mine, a '05 one. The only trick is that you buy the correct sensors, the OEM ones are black, Motorcraft TPMS32. You program them with a strong magnet, I used a magnet out of a dead hard drive, others have used magnets from speakers.
Here's a set of used ones, may be hit and miss if they all work or not...:
4 Ford Lincoln Mercury TPMS Sensor Tire Pressure Monitor System Wheel Computer | eBay
A set of chinese ones:
4 Pcstire Pressure Sensor TPMS for Ford Explorer Lincoln Mercury 4L2T 1A150 Ba | eBay
OEM set:
New Set of 4 Motorcraft TPMS 32 Tire Pressure Sensor TPMS 4L2Z 1A150 BB | eBay
OEM set:
Hi Skauber - I think you helped me on this before ;-) I have a pile of these in my kitchen ;-)
Do you think if I do all four I will have more luck? I was trying to replace just one but now a second has broken. My local garage won't get involved any more as they already fitted the 4 i tried previously and they don't work. The magnet works ok on the originals but nothing happens with the ones I ordered since.
ta
Mike
ta
Mike
Problem solved :-)
Skauber - just wanted to close this out with the news that I just fitted the used TPMSs (ending BA) that you pointed me at and it works!!! Yay! After a year or so it's done. The other parts I bought that are supposed to be equivalent didn't work -- I just re-tested them with the guys at the tyre shop and got nada.
But it's a happy day - and I got two spares in case it happens again.
Thanks for the help.
now I just need to work out how to replace the grille that a pheasant just flew though!!!
Cheers
Mike
Cheers
Mike
