engine swap thread ford f1 1948-52
Did you swap out the tired old flathead, trans and rearend? 1) Log here what you put in and 2) what was the biggest challenge?
My own question is have you ever mounted a 390 in one and a 300 6 cylinder. I'm having trouble finding good info on that. I know someone selling a f100 truck with a 390-4 speed as a possible donor vehicle. Thanks in advance!
https://www.ford-trucks.com/forums/1...l#post15800739
Swapped both trucks to Chevy LT1s with T56 6 speeds. One 350 one 383. Install is the same for any engine, set in place keeping in mind clearances at the cab, steering, exhaust, radiator, and drive line angle. Once all is good with that make up the engine and trans mounts. No issues, I try to take all variables into account before making mounts.
Grey Beard
06-28-2015 02:01 PM
skips69
11-17-2003 09:33 PM
