Strange T case problem - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Log In
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Old 12-10-2015, 02:48 AM
t-loc1 t-loc1 is offline
t-loc1 is starting off with a positive reputation.
I have a 2001 F350 with a7.3 power stroke, 6 speed manual with manual t case and hubs. I have a bad grinding noise when in 2 wheel drive. Similar sound as if you are trying to shift t case into 4 wheel drive too slowly. The grinding is constant in 2 wheel drive, but if I shift it into 4 wheel drive, the noise completely goes away. I have been driving around in 4 wheel drive (T case only, manual hubs not locked) for the past 2 days. If I shift back into 2 wheel drive, a constant terrible grinding noise returns. Any thoughts on what could be wrong, and why it goes away in 4 wheel drive?????
Old 12-10-2015, 10:35 AM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
Post your issue in the Super Duty & Heavv Duty forum.
This in light duty gas.
Good luck.
Old 12-10-2015, 08:31 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
sounds like the transfer case "arm" does not fully move into the 2 wheel position ?
__________________
2002 SuperCrew 4 x 4 5.4 XLT -135K miles -NEW
2010 EDGE FWD - V6 ----------50,000 miles
2002 Explorer 4 x 4 4.0 XLT --- 170,000 miles
2001 SuperCrew 4 x 4 5.4 XLT -235K miles -GONE
Old 12-10-2015, 08:53 PM
pdqford pdqford is offline
pdqford has a good reputation on FTE.pdqford has a good reputation on FTE.
Quote:
Either one or both of the IWEs are not completely disengaging when in 2WD - prolly a vacuum issue.
Whooops! Cancel that - prolly have manual locking hubs
__________________
Jim in Central NY
'79 2WD F-150 Lariet w/302,4spd OD, 228,965 mi. (Original Owner!)
'02 4X4 Navigator w/5.4L DOHC 32v Intech V-8 (VIN R).
http://badges.fuelly.com/images/smallsig-us/50500.png
Old 12-10-2015, 10:15 PM
steve(ill)'s Avatar
does your 4 x 4 floor shift level feel like it strokes full to both ends ? THh F150 floor shift has shown to have "sticking" or "tight" bushings and pins after 10-15 years and will eventually lockup and not move at all.
__________________
Old 12-10-2015, 10:20 PM
steve(ill)'s Avatar
I don't know if your truck looks like this system, but its good info.
http://www.ford-trucks.com/forums/14...-write-up.html
__________________
Similar Threads
Transfer Case Noise wardnikolaus 1987 - 1996 F150 & Larger F-Series Trucks 5 12-28-2015 05:17 PM
Strange t case problem t-loc1 Super Duty & Heavy Duty 3 12-10-2015 10:17 AM
1995 f-250 4x4 grinding aksnopro2 1987 - 1996 F150 & Larger F-Series Trucks 2 11-12-2015 12:55 AM
Manual T-case grinding DrZoom 1987 - 1996 F150 & Larger F-Series Trucks 10 06-24-2015 02:43 PM
Transfer Case/Transmission Grinding heavy_d 1987 - 1996 F150 & Larger F-Series Trucks 0 04-18-2015 01:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
