89 302 to 1995-96 over 8500 gvw
p { margin-bottom: 0.1in; line-height: 120%; } Joe 1989 Ford Wiring Vs 1994 Ford Wiring
Haynes Repair Manual
This guide is to convert a 89 f series with the 5.0 manual transmission to 94 5.8 with manual transmission wiring guide. this is the four plug engine harness on the 89. the 94 has a big square plug after fuse box under hood. I am using the Haynes repair manual for information so cant be certain that the information i provide is correct, i am just converting the colors. i am going to solder the plugs on to the square plug on 94, so i can connect the engine harness to truck without cutting 89 harness by using the plugs from the 89 body (donor). 89 on left 95 on right might work for auto
- 1. Yellow=Yellow
- 37. Red=Red
- 57. Red=Red connects to 37
- 4. Dk Green/Yellow=yellow/black for 94-95 1992-1993 =Tan/Yellow
- 56. Dk Blue=Gray/Org
- 16. Blk/Org=Org/red
- 36. Yellow/Lt Green=Pink
- 48. Wht/Red=white/purple (check this)
- 51. Wht/Red=White/Orange
- 30. Gray/Yellow or Lt Blue/White=Gray/Yellow or Lt Blue/Yellow
- 22. Tan/Light Green=Light Blue/Orange
- 8. Brown=Dark Green/Yellow
- 31.Gray/Yellow=Gray/Yellow
- 11. White/Black=Brown or White/Orange
- 33.Brown/Pink=Brown/Pink
- 17. Pink/Lt Green or Tan/Red=Pink/Lt Green
- 21.Gray/White=White/Lt Blue
- 59.Tan/Red=White
- 58.Tan/Orange=Tan
- 18.Tan/Lt Green= nothing warning indicators
- 12.Lt Blue/Black=Lt Blue/Black
- 29.Dark Green/Purple=Gray/Lt Blue
- 49.Orange=Orange
- 23 Lt Green/Black=none knock sensor
- 24.Yellow/Lt Green= none powersteering pressure switch
- 6.Black=Pink/Orange
- 27.Brown/Lt Green= Brown/Lt Green
- 26.Orange/White=Brown/White
- 47.Dark Green/Lt Green=Gray/White
- 45. Dark Green/Lt Green=Lt Green/Black
- 40.Black/Lt Green=Black/White
- 60.Black/Lt Green=Black/White Connects to 40
- 25.Yellow/Red=Gray
- 10.Black/yellow=Dark Green/Orange A/c
- 7.Lt Green/Yellow=Lt Green/Red
- 20. Black=Black
- 46. Black/White=Gray/Red
- 3.Dark Green/White=Gray/Black
on
Read the title i did awnser the ? Do u even know what were talking about
yes I did read the title 89 motor in 95 truck
on
point out that if you are more clear and actually answer what people ask about
what you are trying to accomplish you will get more help.
Ok master tell me what i gotta do im not being sarcastic i would like to know
What do I need to make this work 89 f250 complete truck motor and trans out in one afternoon no cutting 97 almost out have couple more things to remove lots of cobing. Transmission ears were broken and previous owner made bracket with pieces of pipe for ears works 89 was a manual transmission
on
