Tag decode?
Old 12-07-2015, 08:26 PM
Ron/RPMS's Avatar
Ron/RPMS
Ron/RPMS is offline
Tag decode?
I'm looking at truck and it has been repainted so the door plate is gone. It had a metal tag in the glove box.
Can someone decode it?
2FTJW35LXECA29(XXX) 86
9V W352 D C2 K
I can fill in the (xxx) if needed but I believe that is the serial number.
Thanks in advance.............Ron
Old 12-08-2015, 03:51 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
NotEnoughTrucks2014 is offline
Old 12-08-2015, 06:36 PM
ctubutis's Avatar
ctubutis
ctubutis is online now
Yeah, the online VIN decoder thing is doing a reasonable job here....
2FT J W35 L X E C A29(XXX)
2FT = WORLD MFR. IDENTIFIER = Ford Motor Company of Canada, LTD, Complete Vehicle
J= BRAKES/GVWR CLASS = CLASS H = 9,001-10,000 LBS.
W35 = SERIES CODE = F350 SUPER CAB PICKUP, 2WD
L = ENGINE CODE = 7.5L/460 cid 8-CYL GASOLINE-POWERED, 4/B
X = CHECK DIGIT (IGNORE, FOR FOMOCO USE ONLY)
E = MODEL YEAR CODE = 1984
C = ASSEMBLY PLANT CODE = ONTARIO TRUCK
Axxxxx = NUMERICAL SEQUENCE OF ASSEMBLY (which means it was the XX,XXXth model year 1984 truck built; the A would be a B if they had already built 99,999 of them.
I can't find anything in the book that would explain your metal tag, the stuff on it doesn't fit any for nomenclature I can find.
Source: FoMoCo 1980/89 Light Truck Master Parts Catalog (available on CD from hipoparts.com)
Old 12-23-2015, 07:42 PM
Ron/RPMS's Avatar
Ron/RPMS
Ron/RPMS is offline
Originally Posted by NotEnoughTrucks2014
Thanks that helped.
Old 12-23-2015, 07:44 PM
Ron/RPMS's Avatar
Ron/RPMS
Ron/RPMS is offline
Thanks thats good information. It is what the title says it is.
Old 12-25-2015, 10:37 PM
Ron/RPMS's Avatar
Ron/RPMS
Ron/RPMS is offline
Being I had my camera out this is the tag that was in the glovebox.
This will be my racecar hauler with my open tag for now. I know it won't be overloaded for now.
Is there another place to look for information?
The door tag is missing because of repaint.
This is what I need:
GAWR FRONT AND REAR.
GVWR.
GCWR.
I think I going to stretch the frame and build a ramp body on the back. I just want to make sure I'm not overloading then.
Thanks .....ron
Old 12-26-2015, 12:17 AM
1985 Bronco's Avatar
1985 Bronco
1985 Bronco is offline
Looks like part of one of these
Old 12-26-2015, 06:42 AM
maytag906's Avatar
maytag906
maytag906 is offline
I haven't seen one of those owner cards in ages!
Old 12-27-2015, 09:44 PM
Ron/RPMS's Avatar
Ron/RPMS
Ron/RPMS is offline
That part of the mystery solved thanks. I have the card to it in my owners guide.
Now if I can just figure out the rest.
Old 12-27-2015, 09:58 PM
ctubutis's Avatar
ctubutis
NumberDummy might be able to help but good luck getting a hold of him.
Old 12-28-2015, 11:26 AM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
Looks to me like a W352, from the Warranty Identification Card, is an F350 chassis and cab with a 9200# GVW.
Old 12-29-2015, 07:46 PM
GLR's Avatar
GLR
GLR is offline
The warranty sticker still might be on the door pillar or the door itself. Just covered with paint.
Old 12-31-2015, 08:35 PM
Ron/RPMS's Avatar
Ron/RPMS
Ron/RPMS is offline
I went back out there and looked and it is all smoothe on the door and the pillar. Since its a CC I even looked on the back door. No tag at all.
My biggest concern is the DOT weighing each axle and then they dont have nothing to compare their weights too. What will they do then. I'm not worried about SC so much, but I race in GA, NC, VA, and Maryland too, so I want to keep down the hassels.
Anyone ever been stopped and weighed with a f350? .........ron
Old 12-31-2015, 08:41 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Why can't you use the warranty tag, which shows the W352, and the page from the catalog. I might be able to find the front and rear axle ratings for that GVWR if need be.
Or, are you saying that it isn't a "Chassis and Cab" as the catalog says? If that's true then they might not believe you.
Old 12-31-2015, 08:59 PM
GLR's Avatar
GLR
GLR is offline
Now if this is a crew cab , the W352 doesn't match. Can you get the VIN off the dash? Might want to pass on this. I looked at a "86" CC F350 once. Could not find a warranty tag anywhere. And, the cab, dash,and front end indicated 87-91 style. Passed on that one.
In answer to your other question, I've traveled NY-VA even into NC with my F250 and car trailer (loaded) (sometimes with the backhoe) and never had DOT stop me. Pulled into a weigh station once for kicks, and was told I didn't have to. Most of the travel was along I81.
Quick Reply: Tag decode?
