'35 sedan delivery
#31
Knowing Scott, he will cut and fill, and I don't mean with bondo. I have seen his work first hand. He's too 'thrifty' to order up something NOS from back East....
#32
Everything I've done to this point has been child's play.....compared to the challenges ahead.
I do enjoy this kind of work though.
#34
I got the inner jamb pieces installed for the rear door. getting them to fit over the new steel structure was interesting....
Also put in a patch panel on the lower 1/4....the quality of these leaves a lot to be desired, but it will work.
Next is to tackle the tail pan under the rear door. This will be the biggest challenge of the project.
#35
Coming along nicely. You made a good match for the reveal line of the patch panel.
I feel your pain in the tail pan. The one in my '36 coupe is dented pretty good, and I can't get behind it w/ a hammer
& dolly due to the cross-member. Hate to replace it w/ a repro. Yours is unique to the s. delivery; are you trying to
save it or fabbing a new one? (Good thing you scored on the donor sedan. It will save a bunch of headaches!)
#36
#37
That piece was all bolted in on my panel. I think it's the last piece of the puzzle when wood, body and frame all came together at the factory. I saw someone just use plywood in a pickup and it looked pretty good. I'm thinking a sheet of 3/4" marine if I can get it in 9 foot, then just put my metal strips on top of that.
#38
#39
#42
#45
And yes, Mark's machine work is top shelf for sure. Amazing!
