I Can't Win! IDI Throttle Cable - Ford Truck Enthusiasts Forums
Old 12-07-2015, 05:02 PM
AKHunter93's Avatar
AKHunter93 AKHunter93 is offline
AKHunter93 has a good reputation on FTE.AKHunter93 has a good reputation on FTE.
The throttle cable on my '88 7.3 has been giving me fits ever since I purchased the truck. When I put my foot to the floor, the throttle had a tendency to stick open, and the pedal would only release after I kicked it back with my foot. Being that a new throttle cable was relatively inexpensive, I just replaced it, hoping the problem would be resolved.
No such luck.
It was actually relatively problem free for the last four months or so, and then it started binding again. So I put a heavier spring on the injection pump, thinking that would finally solve it.
It stopped binding, but the pedal became even more obscenely hard to press, to the point that it was almost a workout to do it.
Well, then the plastic bushing that sits at the top of the pedal arm to catch the end of the cable disintegrated. So I had to use some large split shot to take up the slack in the cable.
And then, this morning, a cold morning, the pedal starts sticking again!!
I'm tired of throwing temporary fixes at this thing. I need it fixed, once and for all. It's my understanding that you should be able to work the throttle with a few fingers, just like every other vehicle out there.
I've verified that the injection pump is not the problem. Any ideas?
Old 12-07-2015, 06:21 PM
Pkupman82's Avatar
Pkupman82 Pkupman82 is online now
Pkupman82 has a good reputation on FTE.Pkupman82 has a good reputation on FTE.
Did you try unhooking the cable and checking it for proper function? I guess the other thing I would try is to remove the cable assembly from the truck and try spraying some WD40 or a comparable spray lubricant in the end of the sheath. Work it in and out while spraying it periodically. I would think that should take care of it. My guess is the braided cable inside could be fraying and getting snagged up inside the sheathing. I've had this issue with one of my old gassers.
Old 12-07-2015, 08:35 PM
AKHunter93's Avatar
No, I have not tried it with the new cable, but I tried it with the cable I replaced and it didn't help. It still functioned smoothly when I removed it from the truck, but I replaced it anyway because I had the new one in my hand.
I suppose there's two separate issues I'm trying to deal with. One is the fact that the pedal sticks to the floor sometimes. The second is that the pedal is ungodly hard to actuate. It should be smooth and easy to work simply with a motion of my ankle. It shouldn't take my entire leg to get the pedal to the floor. Right?
Old 12-07-2015, 09:21 PM
tecgod13 tecgod13 is offline
tecgod13 is gaining momentum as a positive member of FTE.tecgod13 is gaining momentum as a positive member of FTE.
Pedal should be easy to operate.
Is it kinked or sharply turned anywhere?
When you unhook the cable, how does the bare pedal feel? It should flop around with basically no effort at all, maybe you need to free up the pedal itself.
Old 12-07-2015, 09:25 PM
AKHunter93's Avatar
The pedal on its own articulates freely. There's no binding in the pedal arm. It does have a few turns in it, simply due to the length. I can see how it would have a more direct path if it were shorter, but it's the same as the one I pulled out of it when I bought it.
Perhaps I should look into shortening it?
Old 12-07-2015, 09:46 PM
FordTruckfan89's Avatar
FordTruckfan89 FordTruckfan89 is offline
FordTruckfan89 is gaining momentum as a positive member of FTE.
try hanging it up and soaking it with a grease or cable lubricant. unbolt the pedal assembly from the truck and check the pivot point for unusual wear. Only thing I can think of is when there is pressure from the cable pulling it at the top of the arm, it gets in a bind. Even try unhooking the end of the cable from the pedal assembly and pulling on the end with pliers, see how it moves.
Old 12-07-2015, 10:28 PM
Red454sedgwick Red454sedgwick is offline
Red454sedgwick is starting off with a positive reputation.
I haven't had any luck my self with after market cables, go to a junk yard and get one, one of a fuel injected small bock will work, also check that you cable hasn't been melted by the turbo
Old 12-07-2015, 10:54 PM
AKHunter93's Avatar
I have verified that the sheath is not being melted by the turbo.
What benefit have you seen in using one off an FI small block, as opposed to the proper part for this engine?
Also, how does your pedal feel? Is it easy to manipulate with your hand?
Old 12-08-2015, 07:25 AM
fhafer's Avatar
fhafer fhafer is offline
fhafer is starting off with a positive reputation.
Have you checked the FIPL/TPS on the opposite side of the IP from the throttle assembly? Is it binding...or is the IP shaft rotating freely? Just a thought.
Never mind, you have the five speed.
Old 12-08-2015, 07:49 AM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
there are three or four different length throttle cables. if the one you put on is not the proper length for your engine, you will get binding.
for the diesel the throttle cable should be 42.25 to 42.5 inches long
Old 12-08-2015, 08:53 PM
AKHunter93's Avatar
Well, the battle rages on.
One of the pieces of split shot that I crimped on the end of the cable popped off tonight.
I'm not in a position to do much in the way of mechanical work right now, but need my truck operable.
Tom, according to the specs online, the cable currently in the truck is 42.2" long.
Old 12-08-2015, 09:50 PM
The small bock was what I had and it would be easier to find in a junkyard, it works just fine. It's been in my 88 since may this year
Old 12-08-2015, 10:11 PM
AKHunter93's Avatar
Alright, I'll look into it. What makes the small block throttle cable superior?
Old 12-08-2015, 10:44 PM
The_Josh_Bear The_Josh_Bear is offline
The_Josh_Bear is starting off with a positive reputation.
Quote:
Quote:
He's saying the AFTERMARKET cables are not the best. The OEM gasser cable isn't superior to the OEM IDI cable, just that it works fine in this application, better than the aftermarket ones.
Old 12-08-2015, 11:42 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
With the cable off, move the pump lever. It should move quite freely, just like a carb lever. If you have to crank on it to move it, something's wrong.
Throttle Position Sensor goes bad every 6 months or sooner BigRedWeather 1994.5 - 1997 7.3L Power Stroke Diesel 19 09-04-2016 07:56 AM
Call out to you 5.0 EFI users Jeff and Nicolle 1948 - 1956 F1, F100 & Larger F-Series Trucks 19 01-30-2016 07:34 PM
throttle cable DB9787 1999 to 2016 Super Duty 1 09-29-2015 07:59 AM
Throttle linkage Spparky82 1967 - 1972 F-100 & Larger F-Series Trucks 9 08-18-2015 09:40 AM
Did my injection pump die? bashby Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 05-14-2015 03:12 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
