300/4.9 6 into big block frame?
Will be putting a 300/4.9 6 into a 92'-96' F250/350 frame that had a big block or Diesel in it.
I'll be starting with a bare frame. Looking for clean frame so don't know which engine it will be set up for, but figure will be 351, 460 or diesel.
If I pull a 300/4.9 6 out of a 95' bronco, I should pull the engine cross member and swap it into the F250/350 frame and use 300 6 motor mounts, correct?
I don't want to leave the big motor cross member in the frame as it will be bigger than needed and in the way. Or is the cross member the same and engine mount are different?
Doing a D60 SAS & high steer so don't want anymore bulk in the way than needed.
Cheers, Allen
Cheers, Allen
