Steering - Ford Truck Enthusiasts Forums
Steering
Old 12-07-2015, 01:50 PM
Ronnie Basil Smith Ronnie Basil Smith is offline
Ronnie Basil Smith is starting off with a positive reputation.
Steering
My steering pulls me to the left and the right and will sometimes go loose. It happens randomly.(used to happen on sharp turns but not anymore) Does anybody know what it is?
Old 12-07-2015, 03:00 PM
mountain dewd's Avatar
mountain dewd mountain dewd is online now
mountain dewd has a brilliant futuremountain dewd has a brilliant futuremountain dewd has a brilliant futuremountain dewd has a brilliant futuremountain dewd has a brilliant futuremountain dewd has a brilliant futuremountain dewd has a brilliant futuremountain dewd has a brilliant futuremountain dewd has a brilliant futuremountain dewd has a brilliant futuremountain dewd has a brilliant future
What kind of truck? Year, power steering, 2 or 4 wheel drive?
Old 12-07-2015, 03:15 PM
wyrm73's Avatar
wyrm73 wyrm73 is offline
wyrm73 is starting off with a positive reputation.
From your description, it sounds like the normal "wandering" a 40 year old truck will do with worn steering components. If you are talking about an active jerk type feedback through the steering wheel, then it is an entirely different animal.
Get someone to help you and have them turn the steering wheel back and forth. Check the entire steering system looking for sloppy parts that don't turn right away when the connected part does. Most likely in the steering gear and/ or tie rods, but really could be anywhere in the steering system. Also have the alignment checked.
Also consider it might be the roads. I once spent a lot of time chasing down an odd steering/ suspension vibration that only happened when it was cold. Turns out 5 warranty service visits later, I figure out the issue was that I take a different route home than I do to work. It was not a cold issue, but a paving issue. Oops. Don't tell the Ford dealer...
Old 12-07-2015, 03:35 PM
77&79F250's Avatar
77&79F250 77&79F250 is online now
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
Steering box sounds shot to me, time for a red head. Red-Head Steering Gears - Custom Rebuilt Steering Gear Boxes in USA
Yes insp all the steering components for being worn out.
Steering shaft (each end), F150 rag joint, F250 u joint, steering box out put shaft where the pitman arm connects. Tie rod ends, wheel bearings, ball joints, F150 radius arm bushings, 4x4 F150 track bar, 4x4 F250 adjustable steering link, king pins...stuff like that.
Old 12-07-2015, 03:54 PM
its a 77 w/ ps and 4wd
Old 12-07-2015, 04:01 PM
77&79F250's Avatar
Used OEM parts guy
And a F150... so insp radius arm bushings, track bar bushings, rag joint. Ball joints, wheel bearings, tie rod ends, steering stabilizer...a little wear and tear on each will added up will make for lots of play.
But it sounds like an internally worn out steering box with what it is doing.
Old 12-07-2015, 04:03 PM
Quote:
Highboy or no?
Old 12-07-2015, 04:05 PM
77&79F250's Avatar
Used OEM parts guy
F150 ='s NO HB
Old 12-07-2015, 04:09 PM
highboys were f250s and above.
Old 12-07-2015, 04:14 PM
So my steering gear box?
Old 12-07-2015, 04:21 PM
77&79F250's Avatar
Used OEM parts guy
This sounds like a bad box and not a bunch of worn out parts...other than all the parts inside your steering box. lol
Have you adjusted the lock nut and screw on the box itself? Over adjusting it can cause those systems.
Old 12-07-2015, 04:28 PM
mechanic did it.
Old 12-14-2015, 10:13 PM
74 F350 SCS's Avatar
74 F350 SCS 74 F350 SCS is offline
74 F350 SCS is gaining momentum as a positive member of FTE.74 F350 SCS is gaining momentum as a positive member of FTE.
My '74 F350 used to wander with a mind of its own but I ordered a new steering box from red head and installed a new rag joint and it was like driving a new Ford LTD afterwards...night and day difference.
Old 12-17-2015, 12:54 PM
Ok so I replaced my steering box and my loose steering went away. But it's pulls to the left and the right if I go past the center spot of the steering.
Old 12-17-2015, 04:36 PM
Does it dart or just pull? Might suggest improper toe in/out of the front wheels.
new steering arm and steering box question and tips 67camaro 1999 to 2016 Super Duty 8 10-13-2015 01:09 AM
Heavy steering thinksnow 6.0L Power Stroke Diesel 10 05-06-2015 07:20 PM
steering gear safety issue phillips91 1968-2013 Full Size Vans 15 04-29-2015 02:55 PM
64 F100 Steering "Clunk" 64rednwhite 1961 - 1966 F-100 & Larger F-Series Trucks 4 01-20-2015 11:18 PM
Steering box failure 2001 f250 4x4 Fire PowerStroke01 1999 - 2003 7.3L Power Stroke Diesel 12 11-21-2014 06:59 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
