interesting big job M-H on craigslist for your viewing pleasure
Just thought someone might enjoy seeing this...
https://seattle.craigslist.org/kit/cto/5349031030.html
He says it's a "Big Job 8". Pretty sure Chuck has said M-H only did conversions up through the F-7 model, not to the F-8. Maybe the seller just meant V8. Hope Chuck drops by to clarify if I've mis-remembered.
Those are Budd to Dayton adapters. They are the perfect accessory to have on an F-7/F-8 imho because they will accept any modern 22.5" tubeless Dayton outer rim. These adapters are not particularly uncommon on the 8 lug x 10" pattern F-7 M-Hs, but are incredibly uncommon on the smaller trucks having the 6 x 8.75" and 5 x 8" patterns. I've seen two trucks with partial sets of the 6 x 8.75" (one with fronts and one with rears) and tried to connect up the owners to join the set, but it didn't work out. I've never seen a set of the 5 x 8" variety but have catalog references for them. Also have the below period advertisement that Chuck came across and sent to me. I've looked for a set of these 5 x 8" for myself, and would appreciate hearing if a set becomes available.
Here is a one of the set that is mounted on Rod Kruithoff's F-7 M-H fire truck.
Here's the 6 x 8.75" rear I found on a truck.
Here's the Studebaker that needed the set of rears.
Here's a period ad for them.
Here's the ad Chuck sent me. Stu
Edit - here's a front set on eBay now. Stu
http://m.ebay.com/itm/NR-monster-truck-axle-rockwell-7-16-ratio-marmon-herrington-4x4-4wd-napco-ford-/371490464354?nav=SEARCH
F-8 M-H "W" Series
Monster Truck Axle Rockwell 7 16 Ratio Marmon Herrington 4x4 4WD Napco Ford | eBay
Chuck
Chuck
No, the first OHV V8s were introduced in 1952 also. Marketing name was Cargo King. The F-7 got the 279 cubic inch / 145 hp / 244 lb. ft. version while the F-8 got the 317 cubic inch / 155 hp / 284 lb. ft. version. Stu
And now I'll ask an "inside baseball" question of Chuck if I may. We know that the R Series (F-2 through F-5) all used the same Fuller or Wisconsin two speed transfer cases. Did the V, Q, and W Series trucks use these same transfer cases? I can imagine this might be so with the V Series / F-6s, but would guess the F-7 / F-8 would have been given a stouter unit. Stu
