Distributor Advance
First, using a vacuum gauge, determine if there is a vacuum signal from that port at idle speed. If there is no vacuum at idle and vacuum is measured as soon as the speed is raised, that is the correct port for ported vacuum, which is what the factory used, originally.
If that port has vacuum all the time, it can be used, but adjustments to idle speed likely will be required.
I use a Carter YF carburetor from a 1970 F350 and it only has one vacuum port. The vacuum at that port is ~5" Hg @ idle and never gets higher than ~11". It did not allow maximum vacuum advance at the distributor, so it was capped and I use manifold vacuum for the distributor advance.
I was running ported advance and could not get going faster than 68 !
And I was wanting more power.
When I read about your ported carb vacuum limiting to 11 hg.
I switched to manifold vacuum and was able to reach 80 !
Not that I do this all the time.
Better throttle response at all speeds.
The only negative is the is a small miss at idle now...
KRinAZ
18
08-29-2017 07:01 AM
Codeseven
07-05-2016 02:41 PM
oldmerc
19
05-01-2016 07:37 AM
rashanny
08-14-2011 09:44 AM
kking1977
04-26-2003 04:31 AM
