Non-freeze plug block heater
I'm going to be installing a block heater. In addition to the standard freeze plug type, Napa has one that's 3/4" NPT. Anyone installed one of these or know anything about them? the description doesn't say where it goes, (well it says freeze plug...i don't think there are any threaded freeze plugs on these blocks) I was thinking this goes in place of the block drain plug? Funny thing is that this one doesn't come up in the options for a '99 5.4l. Current engine in the truck is a 2004 2V. Possibly just a catalog error (shocking!) maybe not though, does anyone know if there were any threaded ports added to the 5.4 blocks over the years?
Does it look something like this?
This is the tank type heater that I used in my '72 Ford Supervan, I also had a rear heater in it. Lots of area to heat. It was 1500 watts and very effective.
When I bought my new van, I ordered it with a factory freeze plug heater, or, at least I think that is what it is, I've never seen anything but the cord, hanging out of the grille.
I think the 3/4 inch model may be one that fits in a hole on the top of the block, rather than a heater hose, or freeze plug.
Thanks for the replies. This is the heater in question:
Part No. 3100002, made by Phillips & Temro. This is Napa Canada by the way, I don't see this type on the US site. I doubt it its intended to be installed in a freeze plug, since this would require replacing the freeze plug anyway with one that had a threaded hole in it. One would just use the standard 1 1/2" freeze plug type of heater in that case. I'll report back if I decide to use this one, a closer read shows it's only 400w...
But it makes sense. Both Powerstroke engines were over 1,000 lbs, and the V6 in my new truck is just under half that. Your 5.4L engine weighs 525 lbs, so I don't think 400W is inappropriate for it.
Originally Posted by 2012 Super Duty owner's guide
Ensure the receptacle terminals are clean and dry prior to use. To clean
them, use a dry cloth.
Depending on the type of factory installed equipment, your engine block
heater system may consume anywhere between 400 watts or 1000 watts
of power per hour. Your factory installed block heater system does not
have a thermostat; however, maximum temperature is attained after
approximately three hours of operation. Block heater operation longer
than three hours will not improve system performance and will
unnecessarily use additional electricity.
Make sure system is unplugged and properly stowed before driving the
vehicle. While not in use, make sure the protective cover seals the
prongs of the engine block heater cord plug
shendren
01-13-2004 08:48 PM
