Zf5 off powerstroke onto idi?
on
I drilled one and it was pretty easy. Remove the adapter from the engine and bolt it to the trans using the couple bolt holes that line up, then use a 1/2" pilot point bit to drill the others. I've never heard of one cracking after drilling, there's plenty material there. I think they use the same casting for both and drill for whatever one it's going in.
Your old xfer case will bolt up, but the PSD transfer case may not work. There were a handful of transfer cases used, and three that won't interchange due to rear output without swapping driveshafts. The differences are pretty obvious.
If it is a S5-47 (tougher front case) it will NOT be the "wide ratio" per se. The S547 got an in between gearing. Gasser/f450 wide ratio for instance get a 5.72:1 first where the "close ratio" gets a 4.14 first. T-19 is about the same as the close ratio, though wide ratios were made (BB gassers). The PSD first runs a 5.08 first. Not as deep as the gasser, but still better than the close ratio.
S5-47 gassers kept the wide ratio with 5.72 first.
Corrected per f834... :P
F834- correct, I misspoke.
Here's a good linky to gear ratio stuff:
https://www.zf.com/na/content/media/...NAL_2-1-09.pdf
Wreckers.towing
03-01-2016 05:18 PM
DIYMechanic
12-07-2011 10:07 PM
