thermostat
Old 12-03-2015, 11:03 PM
jg96powerstroker's Avatar
jg96powerstroker
jg96powerstroker is offline
thermostat
Ok guys I had the 203*thermostat in my rig.... the other day ot wouldnt build any heat at all.... the top hose wasnt hot and the water in the resivor was cold..... so I ran to the parts store got a long stem 195* tell I can get another 203*..... changed it all out and it still takes for ever to build heat.... temp gauge never even gets to the n... on normal. .... thanks for any help in advance
Old 12-04-2015, 06:59 AM
coreyallan01's Avatar
coreyallan01
coreyallan01 is offline
What were the conditions you were testing in? We're you driving the truck to get it up to temp or idling it? You may not build enough heat at idle in cold ambient temps. Do you still have your old 203 stat? You can boil it to test it..
Old 12-04-2015, 07:14 AM
jg96powerstroker
Yes i was driveing and it was about 32 out..... I do have the old one and I did test it.... its stuck open
Old 12-04-2015, 07:17 AM
coreyallan01
Are you sure that you drove long and hard enough to get the new one to open?
Old 12-04-2015, 07:30 AM
BBslider001's Avatar
BBslider001
BBslider001 is offline
Through experience and hearsay, I have seen the parts store ones bad out of the box, both ways. They are either stuck open, or the bad one, don't open well enough.
Old 12-04-2015, 08:11 AM
jg96powerstroker
Yeah I drove it for like 45 minutes it always had amazing heat befor.... I know this tstat is a 195*.... while driveing it will get almost to the n on normal than it drops way back down....
Old 12-04-2015, 08:16 AM
coreyallan01
Man... If its not "overheating" from not opening than I'd suspect a bad stat thats partially open or stuck open.. Course, some experts will come along and debunk my theory..
Old 12-04-2015, 03:01 PM
jg96powerstroker
Ok so after an hour of driveing I came home heat is warm but not as hot as it was.....pulled the napa 195 heated up some water and it is opening at 190... so 13 degrees colder might play a big role in my problem
Frdtrkrul
49
06-03-2018 02:07 PM
cam_12484
2004 - 2008 F150
12-08-2009 07:46 PM
Teroy
03-07-2006 01:03 PM
jduhoski40
10-21-2003 07:39 AM
fordfan
07-07-1999 11:10 PM
Quick Reply: thermostat
