firing order 1982 351w - Ford Truck Enthusiasts Forums
Old 08-06-2003, 08:37 PM
huckermatt huckermatt is offline
huckermatt is starting off with a positive reputation.
i just got this truck and i am not too familial with this motor. I believe it is a 351w calif. model. my problem is I am not sure of the firing order. I am looking in a hayes manual and it states that the order is counterclockwise 1-3-7-2-6-5-4-8. My distibutor has a #1 on it and I am assuming that it is for the #1 plug wire? All the plug wires are in the correct order but the truck is gutless and backfiring please help!!
Old 08-06-2003, 09:20 PM
jpourner jpourner is offline
jpourner is starting off with a positive reputation.
Are you sure that you have a 351W? The 302 and 351w look a lot a like. the 302 firring order is 1-5-4-2-6-3-7-8.
you are correct the 351W and the 302HO firring order is 1-3-7-2-6-5-4-8.
if you have the wrong firring order the engine will run but will have almost no power and will back fire a lot.
I would recomend doing a compression check to give you a better feel for the condition of the valves and rings.
Good Luck.
Old 08-07-2003, 09:13 AM
quentrm250 quentrm250 is offline
quentrm250 is starting off with a positive reputation.
jpourner is correct. Try the other firing order if you want to.
Or if you want just measure the width of the intake on your engine and compare it to a car/truck that you know has a 302 in it. If yours measures the same then you have a 302 or 289 (the 289 has the 302 firing order). If yours measures about 3/4 inch wider then you have a 351w.
Old 08-08-2003, 12:21 AM
horsepuller's Avatar
horsepuller horsepuller is offline
horsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputation
If it's a California truck it's a good chance the ignition is EEC-III (brown grommet on ignition module.)
The EEC-III distributor rotor fires alternately from both sides of the distributor rotor.
The firing order you listed is correct for a 351w, but the spark plug wires for an EEC-III distributor will be wired counter clock-wise in a different order.
351w firing order, CCW: 1-3-7-2-6-5-4-8
351w wire order, CCW: 1-5-7-8-6-3-4-2
Similar for the 302:
302 firing order, CCW: 1-5-4-2-6-3-7-8
302 wire order, CCW: 1-3-4-8-6-5-7-2
Old 08-08-2003, 08:24 AM
HEY! I remeber seeing one of those darn distributors now! That's a pretty funky setup. My dad had a 84 ford f150 4wd that had that distributor. The ECM went out and they wanted like $80 for it at the parts store so I swapped him in a regular distributor with matching ECM box and did away with that P.O.S.! Now if the box ever goes bad it's only $20 or so.
Huckermat....keep that in mind if anything ever goes wrong with that system just toss it and swap in a non-california type distr. and ECM box.
Firing Order saxtonj 1967 - 1972 F-100 & Larger F-Series Trucks 5 02-12-2016 04:59 PM
'88 F250 351W - Need firing order. Dead Miss fordiesel69 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 02-14-2012 12:11 PM
couple problems after F4TE cam install mvvette97 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 09-19-2007 03:07 PM
302 vs 351 firing order bootie Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 9 05-13-2005 07:28 AM
351w firing order jovanie Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 05-04-2003 07:20 PM
Tags
1982, 351, 351w, 82, ccw, cw, distributor, eec, f150, fire, firing, ford, order, truck, windsor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
