1979 f250 Gooseneck under bed hitch
Cant seem to find a current fit from reese or curt. Has anyone installed a new version gooseneck under bed hitch? What vehicle seemed to fit pretty close? I don't have a problem with fabricating but i want to get one as close to what i need as possible. Thanks!
I do not know of any one that manufactures a bolt to the frame/hide-a ball (Draw-Tight or B&W Turn Over style) goose neck hitch for a 73-79.
All I have even seen is a simple steel plate or modded C channel bolted or welded to the frame. Need some measurements of mine?
All 3 truck have them, the blue truck has a plate under the bed and pop up safety chain u bolts.
I am sure a welding shop could build quickly and cheaply what ever we can get measured up for you.
Well after doing some more research, pretty sure NO one makes a bolt on gooseneck for 73-79 Ford.
Here is sort of close. 1979 Chevrolet C/K Series Pickup Gooseneck Hitch | etrailer.com
But here are some for a 1980 Ford 1980 Ford F-100, F-150, F-250, F-350 Gooseneck Hitch | etrailer.com
Here is some more discussion on it. https://www.ford-trucks.com/forums/1...eck-hitch.html
https://www.ford-trucks.com/forums/8...9-f-350-a.html
Very good info here. https://www.ford-trucks.com/forums/1...eel-hitch.html
You can see if a hitch is available for the 99-2015 Super Duties. The rear frame dimension are the same.
78 PEB can you explain your reasoning for that statement. Not saying you are wrong or anything, I am just trying to understand it and learn something.
That is a recesses gooseneck set up, and a good though process, but yes it looks a little under built IMO too.
Normally the drop box is mounted into an all steel flat bed.
Some frame tips
Tips on truck frames
Vertical welds on frame rails??? - Pirate4x4.Com : 4x4 and Off-Road Forum
https://books.google.com/books?id=AoKHCgAAQBAJ&pg=PA782&lpg=PA782&dq=weldin g+and+splicing+truck+frames&source=bl&ots=mJ8-cbU31V&sig=9LfUjq9vFu4-bhpgut35ZL352QI&hl=en&sa=X&ved=0ahUKEwjV2POWlJAh UIx2MKHRreDy8Q6AEIajAM#v=onepage&q=welding%20and%2 0splicing%20truck%20frames&f=false
http://www.thedieselgarage.com/forum...uck-frame.html
The problem I see is that box, I bet it's gonna be awfully irritating when coupling the trailer. The fact that there is no reinforcement worries me, it's just a flat bar and welded to the top of the frame which will be easy to bend. If it was bolted to the sides and maybe had a bit more steel it would be solid. We have one on our f250 with a flatbed and dually adaptors I can get a pic of it when I go to my dad's tonight. The trucks rotted out so I might steal it for my pickup when it's time to stop using it but I wanted to see some other hitches that other truck owners have built.
Look at the size differencw
