What is a DPFE sensor, what does it do? - Ford Truck Enthusiasts Forums
Old 08-06-2003, 07:18 PM
Shakina Glory Shakina Glory is offline
Shakina Glory is starting off with a positive reputation.
My '99 Ford Ranger is popping code. A handheld diagnostic machine shows the trouble code P1401. I looked it up and what I found is, that trouble code corresponds to a "DPFE sensor high voltage". Anyone have an idea what this could be, and where on the engine is the DPFE sensor?
Old 08-27-2003, 07:39 AM
jeremylove jeremylove is offline
jeremylove is starting off with a positive reputation.
Differential Pressure Feedback EGR - it's basically like a MAP or a barometric pressure sensor for your EGR system - it's there to measure the flow of EGR, but it's very troublesome IMO.
The sensor should be either a black or metal box about the size of a large zippo lighter with two vacuum hoses attached to it near the firewall. The hoses should go to your EGR tube between your intake and your exhaust manifolds.
I found the cheapest one at Pep Boys for about $60, but fords wants $90 or so and it's a bit better 'cuz it's plastic and doesn't deteriorate like the metal ones do.
Old 08-28-2003, 09:14 PM
Thanks for the help. the light stayed on for about a week and then it turned off and hasn't turned back on. I take this as a warning to keep a close watch on things but I won't change it unless the warning comes back. Is this okay?
P0401 / P0402 deejdeej Ranger & B-Series 4 06-10-2010 09:51 PM
p1401 Code cabo169 Ranger & B-Series 2 02-24-2008 03:24 PM
What kind of hose? RedBoat Explorer, Sport Trac, Mountaineer & Aviator 5 09-04-2007 12:03 AM
Whats a DPFE sensor mirageford 1997 - 2003 F150 4 01-13-2005 09:57 PM
EGR trouble??? kriswears Explorer, Sport Trac, Mountaineer & Aviator 7 08-07-2004 09:53 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1999, 4cylinder, 99, correct, dpfe, dpse, egr, for, ford, high, located, manifold, pfe, ranger, sensor, valve, voltage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
